MI_Chris
Bronco, Explorer, Edge
Is there a mileage number that this is no longer a concern? Will I be checking coolant levels every week for the time I have the vehicle?
Ducati1098
Nope. It will either happen or it won’t.
roboticsrob
Rob
SoCal
Mazda3
So sorry to hear this, mate. Any update?
Finally got an update from the dealer today, and so far they've concluded that at a minimum, the 7MT is leaking oil, and there is at least one failed seal on the transfer case (the slow leak that many have shown photos of the leaking ATF).
As of this writing, they've ordered a set of all the seals for the transmission and the transfer case, but no ones looked over the engine yet, so there may still be trouble there as well. I did note that the engine oil level was lower than when I took delivery, but the coolant level hadn't changed, so sounds like my issues may be independent of the engine block issue, which I'm still within the date range for. Fun!
indio22
Chicagoland, USA
It is not a recall at this point. Just notification to the dealer if one comes in with this concern, Ford is aware of it and to proceed with replacement if testing leads to a cracked block.
How does this work after warranty period? Is the owner on the hook for a new engine, if the cracked block shows it's face after warranty?
Area51BS
Ron
Badlands non SAS 4dr 2.3
Part of me wants my 86 Ford Escort GT back. No power, no features, but was still running at 130k miles with nothing wrong except and AC evap.
mpeugeot
Yep, must have been operator error after the warranty expires.
flip
flip
Phil
IN
www.ruxerparts.com
Fords
After the 5/60 powertrain warranty, assuming there's not extended service plan, then it would be on the owner. They could come out with a FSA that could extend those time and mileage limitations but that would be at their discretion and probably unlikely.
Ducati1098
Looks like this just became a customer satisfaction program.
Only 131 vehicles affected between Bronco, Ranger and Explorer though, so not really a huge issue.
Beach_Bum
Ken
St. Augustine, FL
Does that mean Ford will reach out to those 131 affected vehicles with a resolution?
Ducati1098
Yes, owner letters are expected to be mailed the week of November 13th. The resolution is engine replacement for those 131 affected.
Dantastic
Daniel
Lake Saint Louis, MO
www.youtube.com
OBX Sas Bronco, Mazda CX-5
I’m curious to know how they identified those 131 affected. Is it anyone who fell within the affected date range or only those who have already reported issues/concerns. I fall within the date range and have the 2.3, but I haven’t experienced any coolant loss other than an initial low coolant that was likely due to a bubble that worked itself out of the line. After filling it, I haven’t had any issues … curious if I should be expecting a notification.
Ducati1098
It's only for specific VINs listed within the date range. Not every vehicle in the date range will be affected. The program will show up on Oasis for dealerships if the VIN is affected. Also I believe you should be able to search for recalls on https://www.ford.com/support/recalls/ which should show whether your VIN is affected or not.
