STIG says Wildtrak height is 2" higher than other trims Sasquatch?!
BigFootie
Wisconsin
Used2jeep
Massachuvian
2007 Crown Vic P71
Benzo
Ben
Bay Area CA
too many to list
Theoretically, is it possible that it may have an optional 2" lift above the Sasquatch suspension? Hmm
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
OK, I get that but from the Ford site...
I would think that the Badlands Squatched and a First Edition should be the same for the undercarriage.
I don’t understand the point you’re making or how it differs from what I said?
It has been understood that WT and FE have squatch standard.
BL does not. As Ford puts it it has its own “unique off road suspension with sway bar disconnect.”
But yes, of course a Squatched BL would be the same as WT and FE... as would any other Squatched trim... because then they’d both have squatch.
And the comment about FE having the BL mechanicals, I think they are referring to the sway bar disconnect.
Also the bilstein position sensitive suspension doesn’t equate to ride height. Those are just the shocks.
So, putting that together with everything Ford has said, what had been understood was there are three different ride heights:
1. Base - OB
2. BL
3. Anything Squatched (including WT and FE)
Ford Bronco STIG says Wildtrak height is 2" higher than other trims Sasquatch?! 1612401239452
2023 Badlands & 2023 Expedition
@broncosor unfortunately Stig was not able to get to the bottom of this! Stig also been reassigned! So I don't think we will ever truly figure it out! I apologise!
Hopefully Stig has been put in charge of marketing!
2Jeeps&PatriotX1
Denver, CO
It is also important to know the overall vehicle height for those of us trying to make sure it will fit our garage. I would seriously consider changing model and/or squatch options if needed so that it will fit in the garage.
I have a hard time believing that a sasquatch Bronco including Wildtrack & FE cant fit in a standard 7’ garage door opening. My 6” lifted f150 on 35s fits in my 7’ garage door opening (w/ less than a 1/2”to spare) as does my wrangler w/ 3” lift and 35s.
Streetfish
New Jersey
2014 Toyota FJ Cruiser TTUE
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
The questions that this chart introduces aside, even the tallest Sasquatch spec which factor in the roof rack height still come in under 80”.
Ford Bronco STIG says Wildtrak height is 2" higher than other trims Sasquatch?! 1612407727617
https://www.bronco6g.com/forum/thre...base-track-for-sasquatch-and-all-trims.12021/
395N
Orange County CA
22 Jeep Rubicon XR
Do you believe the BL Sasquatch should be the same height as the FE, since they both have steel bumpers and disco?
