Tailgate wire FAIL (Edit - or maybe not?)
Mountain Goat
Tyler
'01 BMW 325i, '17 VW Alltrack, '20 Nissan Versa
EDIT: A few good points others have raised - (1) pre-production vehicle, maybe it changes. (2) good to have it accessible in case you want to fish additional wires for accessories from the interior to the exterior, e.g. rear lighting, and (3) apparently the Wrangler is the same way, so perhaps this is to be expected. But still ... seems dumb. Just one man's perspective.
Said halfway tongue in cheek, but is this REALLY how these are going to roll of the production line? They couldn't make the wire (presumably for backup camera) come out behind the spare tire carrier? And then Bronco Nation thought this was a cool enough "feature" to capture it in the photos released yesterday? Did the guy behind the lens simply have no clue what he was looking at and guessed that it was nifty? Or is Ford teasing us to see if it causes an outrage?
I was hoping to find other pictures where the tailgate was not this way, but the latest photos from the assembly plant are the same.
Seems like a disappointing afterthought. Is there any rational reason it should be this way?
*takes chill pill*
I am telling myself this is pre-production. I cannot believe any manufacturer is rolling out a clean slate design in 2021+ with exposed wiring on the exterior of the vehicle.
Ford Bronco Tailgate wire FAIL (Edit - or maybe not?) 1602179760547
Ford Bronco Tailgate wire FAIL (Edit - or maybe not?) 1602179662220
FourHorses
Four Ford Horses and an Expedition
I was trying to stay optimistic about this hole, thinking maybe it was a grommeted hole for other accessories, or something to flow through as well. :unsure:
BroncoKong Jr.
Andrew
I'm sure the wiring will look better on production vehicles. Looks like friction tape wrapped around wires. But I'm not seeing an issue with the hole. That's basically what I expected.
AZHUND
2020 RAM 1500 5.7L 4x4, 2018 Wrangler S 3.6L
With that sweet bokeh - how could you not like this picture of a random wire thing?
Maybe in an earlier design phase they had the spare tire offset to the side instead of dead center like the 'classic' broncos. But then 500 meetings happened by committee they decided to go with a boring copy-cat put in dead center approach instead but forgot the wire hole was still off to the side.
brrke
Vancouver
1997 NA8 Miata
*takes chill pill*
Cost saving for preproduction, most of these will probably be crashed for testing...
Mountain Goat
Mountain Goat
Tyler
Auxiliary overflow drain for when you have 16" + of water in your interior and your washout floor drains are clogged :eek:
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
*takes chill pill*
Counterpoint:
By leaving that grommet in an exposed area, it allows you to add items (lighting) more easily, without having to unbolt and remove the tire carrier.
Apples
Nick
2022 Jeep JLUR, 2024 Nissan Ariya
If it does stay that way, I'll turn lemons to lemonade. With the wire setup like that, there should be plenty of lead to relocate the back up camera to somewhere else, allowing for all sorts of accessories that rely on running through the center of the spare. Also tire covers ....
LandCruiser
Bocephias
CA
I crawled around on the floor under my other 4x4s and that's what the wiring to the trailer hitch, brakes, and other electronic components looks like. This isn't really shocking--especially for this kind of vehicle.
Remember the fit and finish will be appropriate for the cheapest model, and in this case that's sub 30k.
I wouldn't give it a second thought since it seems properly wrapped and not prone to rubbing and I have similar wires on my undercarriage that have seen almost a decade of salt.
aplm7
Andy
Vacaville, CA
2023 Bronco Wildtrak 2 door
I actually like it being that accessible. People are going to need an easy way to re-route the rear camera if they put a trasharoo or tire cover on the spare
hammerdown
DAVID
oklahoma
2006 Ford 150 Screw
Ford: Pay no attention to the man behind the.... errrr... wire behind the tire!!! ???
broadicustomworks
Hanging Rock, North Carolina
Could always replace it with Rigid Galvanized Conduit or M/C cable...
Joking. Seriously, I'm joking.
It would look better hidden more but overall doesn't bother me, still gonna buy one and rock it.
