Thotiana 2 Door Basesquatch
DFNMAN
Anthony
Tampa, FL
21' 2dr, 15' M3, 07' FJ, 03' M3, 79' 928
What I have done so far.....
Bumper Lights & Stickerfab Grille Decals
Window Tint
15% on the front and back.
Ford Bronco Thotiana 2 Door Basesquatch 0BCE96EB-DA32-410E-AA4C-A1E7C6254D0F
Console Vault
It was easy to install, it only took about 20 minutes. My FNS-9 barely fits through the opening, but will work well with one of my compacts.
Ford Bronco Thotiana 2 Door Basesquatch CDD7D0BC-950C-45C4-9A82-555D7AFA54E7
Ford Bronco Thotiana 2 Door Basesquatch CCD497BF-CF91-4B43-A12E-71C6AE6343A8
Sound System
The last time I did this I went overboard and built fiberglass speaker boxes, added in-dash computers, added speaker locations, with multiple amps and DSP/Bass restoration. I didn't want to do that this time. I wanted simple complete sound system. Once I got into it I realized I don't the amount of free time as I once did. Everything was done in two hour chunks over a few weeks, so everything is broken up in the order I did them.
Front Speakers
I went with a 2 way component set I had laying around. They are Infinity PR6510CS's. They are decent but I will probably switch them to a 3 way set soon. They can be found on amazon for $75. If that is your budget they are great. They woofers mounted with no modifications using the adapters that came with the set. For the tweeters I used a set of universal tweeter adapters (https://www.amazon.com/gp/product/B06WGMW76V/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
Ford Bronco Thotiana 2 Door Basesquatch 41-Z1DBP-hL._AC_
They fit perfectly by sliding the alignment pins in the dash through the outside holes and pinching them down with the factory screws. I did have to shave down the sides and open the center hole more for the tweeter to fit.
I used the factory wiring and connected it to the crossover and mounted it under the woofer in the kick panel speaker cavity.
Rear Speakers
These took a little more work. I got a set of 6.5" Coaxial's (Infinity Primus PR6512IS), after hearing the component set I figured if I stuck with the same product line I would be happy. I also like the way the speaker grilles looked.
Ford Bronco Thotiana 2 Door Basesquatch 615HhHyhQsL._AC_SL1200_
These thing sound amazing. These made a huge difference even without them being amplified. If you are only changing speakers with no Amp I would highly recommend putting 6.5"s in the rear. To mount them I purchased a set of universal speaker pods(https://www.aliexpress.com/item/1005001285919509.html?spm=a2g0o.9042311.0.0.140a4c4d0rj8Qu).
Ford Bronco Thotiana 2 Door Basesquatch H0d813d810a1240419287bcbd762df71ev
They are a good quality, and made with out of a thick plastic. I stuck some polyfill in them and installed the speakers.
Ford Bronco Thotiana 2 Door Basesquatch 53ABD84F-6816-49CB-A511-10D6C4DBDFF3
To mount them I got a sheet if 16 gauge steel and fabricated bracket that bolted in to the factory location on the crossbar. To wire them I used the plugs off of the factory speakers. To prevent rattling and scratching I put furniture pads where the bracket connects to the car and speaker. Unfortunately I couldn't find black so ended up using brown.
Amplifier/Sub/Wiring
For the amplifier I wanted to keep it simple, so I got a 5 channel amp. I stuck with Infinity for that and got a refurbished Infinity Reference 7005A (https://www.ebay.com/itm/304179387149?). In the two door so there is literally no place to hide a medium size amp, so it got mounted on the subwoofer box :sick:.
Line Output Converter
Since the Bronco doesn't have a full range signal going to the rear speakers I had to get a converter that did channel summing. I ordered an Audio Control LC7i and found them cheap on eBay (https://www.ebay.com/itm/193131647464). In order for it to send a full signal to all channels you need to wire your rear signal to channel 1 and turn summing on for all channels. Another feature that the LC7i has that makes it very useful is Accubass. When you turn the volume up the factory stereo lowers the bass in order to protect the cheap factory speakers, this corrects that.
Wiring
I ordered a Loopback Harness Elite from LLJ Customs (https://lljcustoms.com/collections/ford/products/2018-2023-select-ford-elite-harness). There customer service is awful and it took almost 3x as long as advertised to receive, but damn it they make a high quality product. It made wiring the amplifier extremely simple. If you get the loopback harness it plugs directly into the stereo and sends the speaker out put and power to the line output converter, then it takes the output signal from your amp back to the stereo harness. That means you dont have to run new wire to your speakers and keeps the amp instal super clean. Well worth the wait.
Ford Bronco Thotiana 2 Door Basesquatch EXTENSionLLJcustoms15ft-2_447ff29f-49a6-4e61-9df1-facf80ca78fb_2000x
For the power wire I ended up using a KnuKonceptz Kolossus 4 Gauge amp kit(http://www.knukonceptz.com/mobile-a.../complete-4-gauge-amplifier-installation-kit/). It is 100% OFC, Knuconcepts make a great wire. I only needed a fuse holder and power/ground wire, but it was cheaper to get a full kit. I ran the power wire down the diver's side and loopback harness down the passenger side to avoid any line hum.
Ford Bronco Thotiana 2 Door Basesquatch 81-LedGR7cL._AC_SL1500_
Subwoofer
The rest of the sound system was so clean I decided to spend more then I planned on a subwoofer. I normally would go with an Image Dynamics ID Max in a sealed box , but i tried a ported JL Audio instead. I was not disappointed, the JL Audio HO110RG-W3v3 is unbelievably powerful and clean. I like a lot of bass and I had to lower my gains by about 70% after tuning it. I could not recommend it more.
The only change I plan on making is swapping out the front speakers for a 3 way component set.
Rear Tray
I wanted something to secure my trunk area while the top was off, which is anytime we have dry weather for a few days. I ordered the JCR Off-road Rack, it is very sturdy and simple to install. It does have to come off when removing the top, so I will probably not have it installed with the top on. I will also be locking the rear seats to it so the can not be lowered to gain access to the storage area.
Leather
Had Cobalt Faced Katzkins installed.
Ford Bronco Thotiana 2 Door Basesquatch 7A1A98FD-87C9-4EDC-B918-0916A681DDC1
Ford Bronco Thotiana 2 Door Basesquatch 28F22B5A-15FC-4659-BCB4-681EEF6DAB37
Ford Bronco Thotiana 2 Door Basesquatch C549CDB7-8ACE-4682-B04F-12F331A12407
j_anderson
Fort Wayne, IN
www.instagram.com
very nice! Audio stuff always confuses me. I'm hoping a company comes out with a sub and amp that can be tucked away in the factory location. I have book marked this thread for future!
how much did you spend on this upgrade?
DFNMAN
DFNMAN
Anthony
Tampa, FL
About $1200
AZ_BRONC
Tempe, AZ
‘17 4Runner, ‘16 BMW 328i, ‘96 Stang GT, ‘19 Mini
Ha, I named my Bronco Robert (BOB) Bronkowski. BOB for Bronco Outer Banks. Also Velocity Blue. I may have to steal your speaker upgrade ideas as well.
Hossfire
Ken
Richmond, VA
'06 Jeep Commander
Rockville makes some nice rear pods as well: https://www.rockvilleaudio.com/mac65b/
These should be good for the Bronco: powder coated aluminum and designed for marine applications. They come in a variety of sizes, including 8" and 6x9s as well. FYI they sell some surface mount adapters for the pods.
DFNMAN
DFNMAN
Anthony
Tampa, FL
Ford Bronco Thotiana 2 Door Basesquatch 1264777__57901.1639443921
I saw those when I got mine. I didn't think they match the Bronco well, and I do not like metal enclosures.
Kramku1
Council bluffs IA
Escape
I ordered 2 door basesquatch may 2021 in white, but that blue 💙 got me thinking, also do you think a Glock 9 mil would fit in the center lockbox.
DFNMAN
DFNMAN
Anthony
Tampa, FL
I would depend on the model.
TXArea51
Juan
Lumberton
FORD Bronco Big Bend SAS
@DFNMAN I looked at LLJ Customs also, I just want to add a powered sub to factory radio. Any suggestion on what harness to get?
DFNMAN
DFNMAN
Anthony
Tampa, FL
You don’t need a loopback for a powered sub. The easiest way would be to run a speaker wire from one of the front speakers to the sub.
SamG
Sam
Detroit Area
sas
Window Tint
Console Vault
Sound System
Front Speakers
Rear Speakers
Wiring
Subwoofer
Rear Tray
Leather
Talk to me about those rear speakers - Do you hear any rattle? I know you mentioned the furniture pads, but it seems there is always an unforeseen squeak or something in all vehicles.
Second - I know very little about speaker operation. If I simply swap my OEM rear speakers for those 6.5" without an amp will a notice a substantial difference?
