jlatigo
jlatigo
joe
1985 Bronco, 14 Raptor, 22 Raptor, 22 Wildtrak
Nice work!
Did you follow any instructions to remove the interior? Or have you done this before?
i have taken apart most of the interiors of the cars i own , and it's fairly strait forward, i did see a couple of you tube videos from a couple called 1Five1 Garage, they break theirs down in various videos, and it's a great reference!
Bruno
Bruno
Montclair
See any place to stash an Aux battery & inverter in there?
49faith
AZ
I was going to do this at some point and time it with upgrading the sub and adding the Kicker Key. Why both the Killmat and Siless foam? For the thermal barrier? What does the Siless do that the Killmat doesn't already? Just planning my project as well.
iBrad81
Brad
Cleveland
2022 Ford Bronco
This weekend i decided to tackle the higher than used to road noise levels on our 2 door. After gutting the interior i am surprised that other than the carpet there is nothing to help keep outside noise at bay.
Taking the interior apart was fairly easy and took under 2 hours to get it done, after a good cleaning of all the panels it was time to lay some killmat down followed by some silex foam, and some sound absorbing felt material on the plastic panels and wheel well cavity. The rear wheels line up pretty close to your ears on the 2 door, i was surprised that there is nothing there to help with the road and tire noise. All the panel clips were lines with tesa tape before reinstalling. I still have the doors to get done(ran out of material) ,but even now the drop in road noise is very noticeable, and the bronco feels more solid.
As long as we had the interior apart we also replaced some of the speakers, the B&O is lacking and the Infinity speakers made it sound much much better.
Overall a good rainy weekend project
Looks great, I sent you a DM of a question I had
FunForAll
WA
Bronco, 2 F-150s, Explorer, Mustang
Well if you get a reading now I'm sure some other 2 door owner will get you there stock rating.
..but it seems to me that different tires and roads could skew the readings considerably.
I performed an extensive sound deadening project on a car several years ago, took a ton of readings, compared with several other cars. Hard to believe them in many cases because cars that sounded loud to me were quieter than ones I thought were quieter. Anyway, the experience was fun. Learned a lot. That car sounded so much better even though the sound meter didn't move as far as I thought it would.
I think I'll have to take another round of sound level readings in our current stable of cars now because of this posting. Lol 😆
FunForAll
WA
It may not be that bad. We have been driving a gen 3 raptor lately and it may have us kinda spoiled with how quiet it is.
Yeah, I have a '17 F-150 that's significantly quieter than our 2-door OB.
marjen
CT
This is something I really want to do on my 2 Door. However after spending time on the facebook group The Deadening, it sounds like there is only one product that really preforms well based on independant data and its not cheap.
https://resonixsoundsolutions.com/
SO I am kinda stuck on weather I should just wait and do it with resonix When I have the money or use some of the other products available. Its a lot of work either way so dont want to put energy into it if there are not really tangible results.
jlatigo
jlatigo
joe
The killmat keeps the metal from flexing, or sounding like a tin can. The foam helps block some of the sound, and insulates the cabin and decouples the panels from the metal making helping with sound transferring. The felt i added in some spots helps absorb sound as well. I bad as this car is insulated i figured it could use all the help i could give it.
jlatigo
jlatigo
joe
What i did definitely helps, are there better products out there... oh yeah!! But at a substantially higher cost. Mas dampend vinyl can also be used, but it adds about 1b per sq ft used and it's a pain to work with.
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
Are you using a special type of felt or would felt carpet padding work? Also what kind of adhesive for the felt? Your answers are appreciated. First time through this.
Roadbeast
Dan
2022 Wildtrak
So I did the same.. dynamat in all the doors. Under the carpet kit. I did the trunk, wrapped the sub box.. I also add kill mat to Dd additional sound proofing.. definitely worth it. Planning on getting a hard top. Trying to make the kids as comfortable as possible.
49faith
AZ
Makes sense, thanks.
jlatigo
jlatigo
joe
Plenty of room inside the drivers side wheel well, a little less on the passenger due to the factory sub
jlatigo
jlatigo
joe
Roberts 70-190A 70-190 Super Felt... https://www.amazon.com/dp/B0049VIQCK?ref=ppx_pop_mob_ap_share is what i used. I've used it for years as have friends of mine, it's inexpensive and works pretty good. On some applications like the rear bulkhead of my raptor i have mulitple layers of it. Only way to make it tolerable inside. 6.2 l supercharged 700hp motor with stainless headers and a race muffler about 12 inches long, dumping out the side before the rear wheels.
Use a 3m spray adhesive and follow the directions!
