- Chris
- Feb 1, 2022
- 16
- 612
- 569
- DFW, Texas
- '23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
- Wildtrak
- I've read a lot of threads on this and seems most are able to still hit Ford's specs with up to a 1.5"-2.5" lift and stock UCA's. I keep reading about our CV's being short and aftermarket UCA's can help with the bind, but how? It would seem CV bind would solely be based on the amount of lift and the higher angle you're putting your CV's/UCA/LCA at on a constant basis. So first, I'd like to understand how the UCA's can help this CV issue... Yes, I've already watched several of the recommended vids on UCA's...
- My target is 2.5" lift with 37x12.5R17 on 0 offset wheels per the recommendation of numerous threads. I have a set of ADS coilovers on order, being fitted with heavier springs currently. I'll be selling my HOSS 3.0 Fox's. There are so many threads on what rubs and what doesn't, and so many variables that can impact, which caster surely plays a role in. So is more caster always better, or to what limit? How negative is the caster getting on a 2.5" lift and what is the recommended degree of correction?
- If I need to get UCA's, I want the best possible compromise of function, maintenance and reliability. I've narrowed down to:
Icon Tubular w/Delta Joint Pro - Per Icon support, these have 1* of caster built-in. DJ Pro's are much more expensive to replace (well retrofits are ~200+, but I can't find rebuild kit pricing for Pros), UCA would have to be removed and appear to need special tools. I'm sure most are aware of the sealed uni-ball design and 90* range of motion. Many use these and have great reports here...
JBA Tubular UCA (1-4" lift) - These have 3* of caster built-in and also note 90* range of motion. Their replacement ball joint appear to be much cheaper @ $67 ea. (their design and built in-house) and you can also substitute a Moog in it's place in pinch. They are also much easier to replace per their design via 4xnuts/bolts. I know these are big with Tacos/Tundras. From the alignment specs, this caster should be nearly on the money as is...
I also looked at SPC, but I keep hearing they're designed for alignment and not for offroad. I've read a lot of threads on QC and bushing/bearing issues as well.
