Castor, Camber, and toe in adjustment won't change with bigger tires, since nothing in the suspension and knuckle has changed. The scrub radius will change based on wheel offset. The scrub radius is the arc of movement when the tire/wheel/knuckle turns relative to the ball joint. Ball joint is the center or pivot point, the arc of movement is at the center of the tire. As the wheel offset changes, the actual position of the center of the tire changes relative to the ball joint. If the wheel/tire center is more outward, the distance of the arc of movement of the center of the tire is moved further away from the ball joint, and this is an increased scrub radius. Increased scrub radius will put more strain on the steering, and can/will take more steering effort to turn the tires.thank you for the response.
full disclosure: i'm going to have to look up a few terms but I do appreciate the help.
Last statement can't be emphasized enough. The majority of aftermarket wheels start with a zero offset or negative offset. Many buyers are only looking at the design unaware of the stresses that are applied when opting for a wider/taller stance.Castor, Camber, and toe in adjustment won't change with bigger tires, since nothing in the suspension and knuckle has changed. The scrub radius will change based on wheel offset. The scrub radius is the arc of movement when the tire/wheel/knuckle turns relative to the ball joint. Ball joint is the center or pivot point, the arc of movement is at the center of the tire. As the wheel offset changes, the actual position of the center of the tire changes relative to the ball joint. If the wheel/tire center is more outward, the distance of the arc of movement of the center of the tire is moved further away from the ball joint, and this is an increased scrub radius. Increased scrub radius will put more strain on the steering, and can/will take more steering effort to turn the tires.
BTW, when folks report that they have broken a tie rod, it would be helpful to know what wheel offset and tire size they are running.
Also would be extremely helpful to know if, fo example, vast majority are driver side or if breaks are evenly divided. It would to me indicate something inherently wrong with suspension geometry on that side.Castor, Camber, and toe in adjustment won't change with bigger tires, since nothing in the suspension and knuckle has changed. The scrub radius will change based on wheel offset. The scrub radius is the arc of movement when the tire/wheel/knuckle turns relative to the ball joint. Ball joint is the center or pivot point, the arc of movement is at the center of the tire. As the wheel offset changes, the actual position of the center of the tire changes relative to the ball joint. If the wheel/tire center is more outward, the distance of the arc of movement of the center of the tire is moved further away from the ball joint, and this is an increased scrub radius. Increased scrub radius will put more strain on the steering, and can/will take more steering effort to turn the tires.
Geometry.Thanks for the good inputs. Steering really is science.
And center of gravity. Both are raised slightly relative to the ground. Besides a higher center of gravity, the driver will also feel more give in the taller tires. Taller tires are for off road ground clearance, any effect on street handling will be negative.Roll center will be affected. Where the center of the tire contact patch meets the surface it is sitting on is one of the points that are used to determine roll center. The other points are all generated off suspension pivots. The distance between the two increases with taller tires which results in a different roll center.
Wheel Alignment System |
Adjustment | Front of Lower Arm | Rear of Lower Arm |
Increase caster | In | Out |
Decrease caster | Out | In |
Increase camber | In | In |
Decrease camber | Out | Out |
Increase caster and camber simultaneously | In | — |
Decrease caster and camber simultaneously | Out | — |
If I’m not mistaken, in the rear of the Bronco, with the panhard rod, both CoG and RC will be raised together. In the front with the IFS, it’s not unlikely the RC would lower* while the CoG raises. Would have to have specifics on the suspension geometry for definitive answer.And center of gravity. Both are raised slightly relative to the ground. Besides a higher center of gravity, the driver will also feel more give in the taller tires. Taller tires are for off road ground clearance, any effect on street handling will be negative.
Lift kits also raise the roll center and center of gravity. Most will do lifts and larger tires for looks, which is fine, but it will have a negative effect on street handling. Nothing new here.
Two elements here with just a tire change. Roll center won't change relative to the chassis/body, will only raise relative to the ground since the whole car sits higher. Nearly identical with a change in center of gravity. In the rear the track bar/panhard only affects the roll center, has nothing to do with CoG. CoG is based on weight, not suspension geometry. Roll center with a track bar is basically at the height of the bolt/pivot at the frame side mount. Have no idea where the CoG is on a Bronco.If I’m not mistaken, in the rear of the Bronco, with the panhard rod, both CoG and RC will be raised together. In the front with the IFS, it’s not unlikely the RC would lower* while the CoG raises. Would have to have specifics on the suspension geometry for definitive answer.
You’re right though, CoG would go up, which rarely affects handling in a positive way. Good news is it seems there are plenty of folks running taller tires on these vehicles without any tremendous downsides where handling is involved.
*Eta: Front roll center would go up but would lower in relation to the CoG.
It’s been a long time for me as well and I used to race Mac strut/torsion beam stuff which is why I was completely forgetting to consider the back end in my original comment. Started to wonder if I even still had my old papers but then remembered we live in the magical age of the Interwebs now.Two elements here with just a tire change. Roll center won't change relative to the chassis/body, will only raise relative to the ground since the whole car sits higher. Nearly identical with a change in center of gravity. In the rear the track bar/panhard only affects the roll center, has nothing to do with CoG. CoG is based on weight, not suspension geometry. Roll center with a track bar is basically at the height of the bolt/pivot at the frame side mount. Have no idea where the CoG is on a Bronco.
In an off road car, a higher roll center resists body roll in off camber situations, but it needs to be high to matter much. However, a high roll center reduces driver feel, so you can get closer to the edge without feeling it so much. In road race cars the roll center is put very low to increase driver feel, and stability is done with spring rates, sway bars and other geometry.
Roll center relative to CoG will affect handling and feel. I'm not up on IFS/A arm geometry, I race Jeeps and buggies. Would have to get my books out again.
Since it looks like you're in the business of alignment, I ask you to PLEASE take a minute to read and comment on the included Post (kinda related) that I created a couple days ago... It didn't get many views, so I didn't get feedback about my issues with Castor... or the solution by my aligner.Castor, Camber, and toe in adjustment won't change with bigger tires, since nothing in the suspension and knuckle has changed. The scrub radius will change based on wheel offset. The scrub radius is the arc of movement when the tire/wheel/knuckle turns relative to the ball joint. Ball joint is the center or pivot point, the arc of movement is at the center of the tire. As the wheel offset changes, the actual position of the center of the tire changes relative to the ball joint. If the wheel/tire center is more outward, the distance of the arc of movement of the center of the tire is moved further away from the ball joint, and this is an increased scrub radius. Increased scrub radius will put more strain on the steering, and can/will take more steering effort to turn the tires.
