UPDATE/ Ford IS Warranting MIC top v2 developing hairline cracks
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I took delivery of mine a week ago, and am not quite at 300 miles. I noticed mine is missing the two bolts that secure the clamshell at the to top front where the front panels meet the rear clamshell, so the connection plates rattle and Squeak a bit
The holes are a bit misaligned too, so after reading this thread, I cannot wait to hear what Ford has to say about it!
Somebody had the same issue early in production last year. I don't remember how they handled it but it might be worth searching the forum.
Good lord - makes me want to 99 mine until 2028. Maybe Ford can figure something out in 5 years.
I was really hoping for a mod top in 23 but I have a feeling it will get pushed to 24. My first top had air pockets (blisters) in the outer layer and edges inside sharp enough to bring out the first aid kit. đź‘Ž
BigHoof
PA
Ram 2500
Wow! Definitely should be a bolt there. Not even close to lining up. The front 2 bolts are fixed by the holes in the rollbar so that means the top is skewed rearward somehow? This is a 2 door.
Ford Bronco UPDATE/ Ford IS Warranting MIC top v2 developing  hairline cracks Bolt
BigHoof
PA
Ram 2500
Side view just after the bolt was removed also 2 door.
Ford Bronco UPDATE/ Ford IS Warranting MIC top v2 developing  hairline cracks Bolt 2
Bronco B
2023 Bronco BD, 2017 Indian Chief Darkhorse
Just wondering if anyone else is having this same problem. Both the drivers side and passenger side are developing these hairline cracks in the lower window panel area. It hard to see in the picture but seems like I'm getting more and more every day
I can't tell - is this a 2dr or 4dr roof? I'd be curious if there's any trending data if one seems to be suspect over the other.
Fold
Bronco, Kia EV6, Mach E, Miata
Thanks for the pics! Mine is also 2-door. I just took mine in and will have to schedule an appointment to confirm the bolts are missing before they will order the part, because despite the service advisor asking me to remove the panel to see, he could not confirm the obvious.
BigHoof
PA
Ram 2500
Wonder why the alignment is off though? It's not just a small amount. Should of been flagged at the plant when the bolts would not fit but apparently they sent it on down the line. Quality at this plant seems to be severely lacking. There are numerous easily seen defects slipping though, just imagine how many are unseen. No pride in what they do, almost like we are back to making cars in the 70's before changes were forced due to competition from Japan. Then again having worked in a similar environment, management pressures and their lack of concern other than for quantity creates that type of atmosphere.
:oops:
Fold
:oops:
...but wait there's more. I did go ahead and take the top off completely and found several major scuffs and scratches presumably from when the top was initially installed. I have a hoist in my garage left over from a Wrangler, which smoothly lifted the top without incident. I also sent these pics to the salesperson. All but the chipped paint are totally hidden when the top is on.
Bronco671
Tim
Washougal
69 Bronco, Ram 1500
Mine is a 2 Door
Bronco671
Tim
Washougal
69 Bronco, Ram 1500
Hello all,
Just a quick update but my dealership and Ford have decided to replace the MIC top under Warranty. Hope others have the same outcome.
mpeugeot
Hello all,
Oh, I am amused now for sure.
Just make sure that you are not over 36k miles.
@Ford Motor Company dealership said, "sorry it's not even a year old but you are over the miles". I think that's dealership speak for, "Go eat a bag of sausages".
FreddyS
Freddy
2022 Badlands Sasquatch
Hello all,
Glad to hear that. I'm going to take mine in next week for the same issues under the windows. I hope I have the same outcome. The build quality of these tops is horrendous. My wrangler top was much nicer quality. I really expected the same or better, but got much less.
Fold
Even though mine is not yet cracked, I am pretty sure at least the top will have to be replaced. Good to know they are starting to follow through for others. So far they have ordered replacement bolts and will then need to physically confirm the bolts will not fit. The dealership also did not want to remove the whole top until the bolts arrive.
Deleted member 32220
Guest
Ford Bronco UPDATE/ Ford IS Warranting MIC top v2 developing  hairline cracks 20221021_173551
Mine is the same under and behind right rear window. 900 miles
FreddyS
Freddy
They have agreed to replace mine as well. I was told Ford was starting an investigation about the matter. Unsure how long to receive another top.
Busterbronco1
Andy
2005 Mustang GT Premium and 1982 F100 Short Bed.
just noticed today..... mine is developing hairline cracks on the driver's side - 2 door. Not missing any bolts.
