Update: 3rd Differential lasts 2 months New Front Differential Implodes in 2 miles
Gotchaa
Gotchaa
Los Angeles
Tesla
As you said, if nothing is wrong then nothing gets repaired. But if there is a potential problem I would rather know what potential issues it could be from and know where to start looking. Obvious issues aside I would have the TSB to discuss with the dealership. Without it I am in the dark and the dealership has the upper hand. This is not my first rodeo with a new vehicles and having issues (Chysler, Isuzu, VW and now Ford again).
I think they should be issuing a TSB for the differential and seal leak, maybe its a matter of still trying to determine how many Broncos are impacted and from which plant or build dates, etc…it can’t be easy to sort out until they start seeing lots of these issues. Honestly I would not have noticed the first leak if I was not changing my oil.
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
Yes I am glad it happened right away. I checked in on it today, and they have a new from differential ordered so far. I am kind of worried about where the drive shaft connects to it. I was assured everything would be inspected and any parts needed would be ordered under warranty.
I am waiting to hear what happened, right now their are working under the assumption that it was a defective part from the manufacturer.
I called Ford customer service and they were pretty much useless, all they wanted to know is if I wanted to request a repurchase and go through that process. I asked about extending the warranty and I was told nobody at Ford Corp could do that. I don’t know if this is true or not. But I have to say it really is not a good feeling to be dealing with this at 8k miles after waiting 3 years and wondering when the next issue is going to happen.
Honestly going 50mph and having the Bronco buck like that was very unsettling, it could have been worse had I been going faster, thank goodness for LA traffic I guess.
To me this is a safety issue and more importantly a trust in the Bronco issue, like if I can’t have it run on paved roads without issues, am I going to feel comfortable wheeling again with lockers on wondering if I am going to get stranded deep on a trail?
I mean just look at the threads with people having this issue with the front differential, how is this not a manufacturing part issue?
I had a new in the crate differential shipped and installed and it failed. Unbelievable, not even a TSB about the leak.
They can’t extend the warranty, but they can and do offer ESP service plans. You have to ask, they won’t just give it to you.
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
I had the leaking front differential and they just replaced the seal. I haven’t had a problem since.
HotLap
Bradley
CA Central Coast
2018 Ford Raptor and 2019 Yamaha XSR900
Your issue sounds a lot like when my 2013 platinum SCREW 4x4 had an issue with an IWE vacuum leak that resulted in the truck tying to engage 4L at 55mph…made a hell of a racket, grinding/squealing, sounded like a front wheel had come off and I was driving on the rotor…good luck!
indio22
Chicagoland, USA
How bad typically is the leak? Just a weeping or something more substantial? All my other older 4x4s leak to various degrees, so I guess I'm use to it.
orion
Jeremy
17' F-250, 17' Explorer
Your truck wasn't trying to engage 4L, IWE (integrated wheel end) with no vacuum was trying to engage the hub. It's a common issue and an easy fix and not too pricey.
To the OP, I don't know why they didn't just re-seal your existing front diff. The one they put in that grenaded, it was probably messed up from the get go, aka manufacturer defect like they said. They will get the new one in, see about any other damages caused by this incident and that should be the end of it. I think your over thinking this whole thing.
BlueBronco
DFW
'16 F150 KR - '21 BL - 23' OBX
Fighting the IWE issue on my F150 right now. Replaced the check valve and solenoid but noise is still there. Hubs were replaced about 6 months ago as well. Going to tear back into this afternoon and try and get it figured out.
OP, sorry about your bad luck and hope you get it sorted out.
615_Bronco
Cheatham, TN
2022 Bronco 2D BL, SAS, MT, & 2015 F-350 DRW
Not much, I went a month or two and 3-4 thousand miles and only put roughly 2 oz in it twice.
Easy to spot too if you have a skid there.
retiredarmymp
Steven
Whitehouse, Texas
It formed a drop on the bottom of the differential but I never had any drip onto my garage floor
Ctholl
Casey
WY
Jk wrangler (bronco on order)
Fixed the leak boss, drained all the fluid out... She won't leak another drop boss
wjtinfwb
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
9 years ago my new Chrysler 300 developed a dash panel short that took out all the gauges. Unfortunately, my model (Varvatos) used a specific instrument cluster that was not available and not interchangeable with a standard 300. After 9 weeks in a rental car due to no gauges, I asked about a repurchase agreement. They started the paperwork and agreed to refund essentially 100% of the initial purchase price. I agreed and the process started. Before the actual repurchase happened, the part arrived, was installed and all was well. I called Chrysler and told them I liked my car, just didn't want to screw myself once the warranty expires. I'd keep my car and waive the repurchase if they'd give me the 7/125k extended bumper to bumper warranty. Nope, I was surprised to hear. So instead of a 2k warranty, they paid me 44k for a year old car.
Hdscreens
Will
2dr Bronco Badlands
I think they do have fluid in there from warehouse unless whoever fills it missed one. I had a transfer case on Raptor pickup replaced at 5500 miles and I remember the first one was sent back cause the fluid had all spilled out inside crate it was sent in.
I am not sure, but I believe they ship from the warehouse with it, I would think it would be checked. Let’s see what their investigation finds
XirallicBolts
Paul
Wisconsin, USA
2016 Flex EcoBoost, 2010 Milan
Hopefully it gets resolved soon enough.
Mistakes can happen of course. My 22 Silverado was leaking transmission fluid from the factory, and a shop once installed a replacement control arm on the wrong side of my Dodge -- no idea how they got the bolts to line up.
Gotchaa
Gotchaa
Los Angeles
Tesla
That is what I am hoping, haven’t heard back yet, but I know they ordered a new diff on Friday.
In terms of why they didn’t just replace the seals, it was leaking in a few places and they follow Ford guidance on testing. Perhaps Ford is seeing return visits for people that have similar problems as well.
Gotchaa
Gotchaa
Los Angeles
Tesla
Got the second front differential installed, went over the install with shop foreman and tech while on the rack. They checked the oil, drained and refilled it from the factory to be sure. No issues with the transfer case or drive shaft.
Set it to Sport and drive it home. Upon pulling into the driveway smoke smell coming in through AC, opened hood and looked like burn white smoke coming near the exhaust area.
I am hoping this is just a new diff burn off from any spill that may have been there from the change.
On the rack I didn’t not see any residue so who knows.
Going to keep it in sport mode and see if it burns itself off eventually.
Good news is it hasn’t imploded yet :)
