- First Name
- Mike
- Joined
- Oct 16, 2020
- Threads
- 11
- Messages
- 258
- Reaction score
- 552
- Location
- Washington
- Vehicle(s)
- Raptor, Ranger, Mustang, Focus, Explorer
- Your Bronco Model
- Badlands
- Thread starter
- #1
Been a bit of a process to get here but I finally have both of my gull wing doors installed in my 4 door to replace the rear hard top glass.
Product info:
https://veloxoffroad.com/bronco-4-door-model-drivers-side-gullwing/
Step one was to remove the glass from the hard top. I wanted to keep my glass intact and not mess up the MIC top trying to cut the seal with a knife so I reached out to a local glass shop to see if they would take car of it. Took the shop about 30 minutes and cost $200 but worth not breaking a window to me.
Home in the garage windowless
Also did my buddies 2 door at the same time
Taped up the top to prevent scratches
two door install
The doors install with an EPDM rubber gasket that's adhesive and has an inner and outer frame that bolt together to sandwich the seal. Its a strong fit and seals well.
I left my passenger side open for cargo area access and have a molle panel and air compressor/first aid kit set up on the driver side.
Solid product that adds a lot of utility to the bronco for me. Its so nice having my air set up ready to go, just pop the door, flip the switch connect tire.
Product info:
two door install
