What should I upgrade first? Wheels, Tires, or Lift?
PainlessSauce
Brandon
Manhattan Kansas
2021 hyundai sonata SEL Plus
Pretty much the title...I obviously want to do all 3 at once, but my wallet disagrees. What do you suggest getting done first?
I have a 4dr black diamond non-SAS and I want to add 35s with new rims and the 1.5"-2" lift. And I want a capable lift too, one that can handle off-roading, not just a spacer which I hear hurts your off-roading capabilities. So that would probably be a coiler swap.
TCC
TC
Western NC
OBX -> WT
Speakers🤣
Do the tires/wheels first. Stock suspension works fine with 35’s on +30mm offset wheels (same as SAS). Had this on my OBX. Never felt the need for a lift other than a 1” front leveling Kit.
RC Bronco
Kansas
I started in your situation and have held out over the past 20k miles - unless you're looking to hit some level 5+ trails right now, you're well enough equipped to handle most trails
What I did first was upgrade the entire sound system, cause that gets the most use on a daily basis
I haven't yet upgraded my wheels or tires, but just purchased Eibach Pro Truck 2.0 Coilovers and some Zone UCA's and those will get installed at some point in the near future. The next big purchase will be 35's
stickshifthappy
RVA
Ford Ranger, 65 Mustang
Personally I'd upgrade my bank account first.
PWillette
Parrie
Maine
You can get by w/o a lift to add 35s, just remove crash bars. If you went w/ a 35 x 10.5 tire you could stay with the OEM wheels until ready to upgrade. If going 35 x 12.5 will need a wheel w/ minimum +30mm offset.
1st 75th ranger
jeffrey
nj
i" level tires will fit
if needed perch lift before spacers
marktwain2001
mark
earth
23 bronco
Billstien 5100s will provide up to a 2 inch lift and level the vehicle at the vehicle at the same time. It will also transform the handeling. This is the first upgrade.
Area51BS
Ron
Badlands non SAS 4dr 2.3
My thoughts exactly. Wear out the OEM rubber first and the sound system needs advance life support.
Twister22
michael
lone jack,mo
2012 Raptor 1965 Mustang 1968 Mustang
I went with a 3” Readylift 17x9 black rhino wheels 37 inch Yokohama MT
Aonarch
North GA / MT
Suspension first and foremost, and don't cheap out on a spacer lift, nor go too high. IFS lifts really need to be limited to 2-2.5". I know people go 3" here, but lifting IFS just decreases down travel and puts your CVs and tie rods at nonoptimal angles.
I have the Ford Performance 2" Lift Kit and absolutely love it. It uses custom valved 6100s with Sasquatch springs.
RHeinz
Ric
Houston, TX
For going to the mall….. you absolutely need all of the mods you mentioned.
For off-roading, your vehicle is probably already quite capable. Why not give it a go first and discover what you actually need for the type of off-roading you’ll be doing.
BlueBronco
DFW
'16 F150 KR - '21 BL - 23' OBX
Search the marketplace for Squatch take-offs. That is going to be the cheapest coilover lift you can find.
