Will it be easy to DIY Sasquatch a base Badlands?
Silver-Bolt
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
Very basic aftermarket wheels like a Method with BFG KO2's will run you $2500 from Tirerack. Lift and labor?
Jr87mustang
Josh
Northern Cali
Decent lifts for Rangers look like they are $1000 or less and it doesn’t take brain surgery to put it on yourself. You would have to have an alignment done. I think you can do better than $2500 on wheels and tires if you shopped around. Even so, $3500 is way cheaper if you just want the look and don’t need the beadlock rims or front locker.
TNcoupe
Decatur,TN
2022 Badlands, 1970 Bronco, 1955 T Bird
I turned 37s with 4.56 gears and a C4 automatic and a Dana 20 t case with 2.46 low gear in it. 4.46 wont be a problem for 35s.
Jchetty
Jay
Central Jersey
09 Tacoma, 00 Lightning
The badlands for instance uses different shocks than the base so pretty sure sasquatch has different shocks from base.
The OP asked for differences between a Sasquatch and Base Badlands. Both get the Bilsteins.
You are talking about a base model and a Sasquatch. Yes they have different shocks but this is not what the thread is about.
Used2jeep
Massachuvian
2007 Crown Vic P71
The shocks are different and I would guess the spring rates as well.
Guessing, without delving into thread after thread, that some people speculate they are different. Some believe they are the same. The only difference being in the limitation of travel.
Used2jeep
Massachuvian
2007 Crown Vic P71
A topic literally nobody has ever discussed before... ever...
Nope. Not sure how this topic could have bounced down the road without us beating that horse to water.
Used2jeep
Massachuvian
2007 Crown Vic P71
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
So the only difference between a Badlands and a Sasquatch Badlands is 4.7 vs 4.46, a small lift and of course the 35 tires and fenders.
We already know we can order the fenders as an accessory and of course 35 tires.
I would gladly order Sasquatch from the factory, but I need a roof rack and it seems the roof rack cannot be ordered as an accessory from the dealer. So I am stuck getting a base Badlands. Will it be easy for me to add 35 tires and will the 4.46 be an issue?
You can get the 4.70 gears with the automatic, no Sasquatch .
Razorback
Dallas
Lincoln MKX
You would also need the wheels to fit the 35s. They're wider than the 33s.
2Jeeps&PatriotX1
Denver, CO
not according to the order guide you can't. I know the B&P allowed it but order guide states otherwise.
