window getting caught when opening door
jd-ford-hd
Tennessee
ā€˜16 Explorer, ā€˜13 F150, ā€˜99 F350, '74 Bronco
Watching the video shows exactly how "TO" open the door (1st opening) and how "NOT TO" open the the door (Next 2 openings). Intentionally trying to beat the window motor can be accomplished.
Pbloom49
Peter
Connecticut
2021 Bronco Outer Banks
You canā€™t just open the door. You need to pop it open give it a second and the window will come down.
Absolutely Not and with the 4 door it is almost in possible to do that with the rear doors
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
Had the EXACT SAME ISSUE with my 4Dr Base Squatch on the rear dirver's side door.
This was hugely annoying because my 5 y.o.'s car seat was behind this door. ONLY WAY TO AVOID is to hold the door closed with one hand while opening the handle with the other. Once the window goes down then open.
Ford needs to re-engineer this!
BUCKIN-ALEX
Alex
CA
1997 Jeep Wrangler
I honestly don't know why they engineered it that way. A simple fix so the window would not get caught up like that is lower the windows slightly already if you are near the car with your keyfob or as long as the car is unlocked have the doors lowered already to avoid that.
Grant3168
Grant
Denver, Colorado
2013 G37, 2006 G35
Reset the window limits.
Lower window, hold window switch five seconds. Raise window, hold window switch five seconds. Repeat two times. Roll window back up. Exit vehicle normally.
That's exactly what I have done to reset the windows in my G35 coupe. Had to do it when I had to replace the window motors. I think this could also happen if the car's ECU memory has been reset or if its been unplugged from the battery for an extended period of time. Maybe during the factory construction it needed to be reset and never was?
cowman
cowman
texas
ford
I have this issue on 2 Door Bronco. Feels like windows is going to break when opening the door. any one with same issue?
Not rocket science .... it takes the same about of time for the window to come down as it does to go up..... about a 1/2 second.... just slow down.... :)
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
I did the reset as suggested multiple times, no bueno. In fact made it even worse. Ill see if dealer can get it fixed. And for those who said just open it slower, lol. To be successful you would have to hold the door in with one hand while using the handle with the other. Needless to say, a huge pain in the ash...
SurfsUp85
Joshua
Windsor, Ontario
youtube.com
2021 Bronco 4 door Outer Banks, Kia soul 4u
Cheers!
Worked like a charm šŸ¤™
xcxv
xcxv
hmm
Jeep Bronco
Update: Took it to the dealer today. They took the door panels off and reinstalled the window. Now window doesnā€™t get caught when opening the door like any other cars.
*Reset procedure doesnā€™t work. Must have them physically reinstall the window. Seal is not the problem either.
SVTLightning
Christian
Canada
Titan
So what does re-installing the window actually change? Seems odd.
BroncoBuckaroo
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
in my case, driver's side is 'normal' like other cars with frameless doors. passenger's side is getting caught and wobbles even if i wait 1/2 second to open after pulling handle.
[/QUOTE
just Checked ..mine are good
gtx_bronc
GTX
Same, the negative nancy's saying open it slower are either the worlds most tolerant consumers or more likely don't have one yet. My 2018 mustang has frameless windows and it does not have this problem. I'm chalking this up to the growing list of first year oddities.....still love it and still worth it :)
UberGadgetFreak
Mt. Holly, NC
21 FE Bronco 22 FE Mav, 23 Mav Tremor, 03 Marauder
Glad I remembered seeing this thread. I enabled Global Close on my 4 Door FE yesterday, but the passenger front wasn't rolling up. The window limit reset fixed it. Passenger rear door was okay though.
CliffCo
Cliff
Charlotte
2021 Iconic Silver, Big Bend Sasquatch (MIC top)
Had the battery changed (Dirt Mtn wore it out), and now the front windows arenā€™t indexing. I tried the reset method and didnā€™t work. Is this with the Bronco started up or just on? Door closed or open? Dealer thinks itā€™s a bad switchā€¦
thanks!
