Windshield washer not working -- no fluid coming out
Discusman68
Travis Bates
Ohio
2022 Bronco outer banks
My windshield washer is not working. The motor works as I can hear it but no fluid is coming out. Is it a clog? How can I clear it??
Discusman68
Discusman68
Travis Bates
Ohio
Front. I have soft top
604Bronco
British Columbia
www.bronco6g.com
Has it never worked, or just randomly stopped recently?
I‘ve experienced it randomly stop working, but then it’s fine next startup. Heard the same thing from others too.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Mine randomly stops working then returns to normal.
Brockdog12
NTX
2022 Explorer ST-Line
Mine would take forever to pull fluid even with a full reservoir.
Leland
Anthony
Pittsburgh
Wildtrak, Mustang MachE GT, Raptor, Subaru (2)
Mine originally stopped shortly after purchase and was fixed at the dealership. 18 months later not an issue
Lifeliberty
Moonbeam👀
Columbus, OH
harpo
not as many as I thought
I have had both issues. Sometimes the motor doesn't come on. But if you stop, turn the motor off and back on then the washer fluid pump would work.
This past 2 weeks it does what you describe. I can hear the motor but nothing comes out. But if you keep the pump going a long time it eventually works.
No idea why, maybe a back flow valve is stuck open so the pump has to prime itself?
If you find a solution post it
Moto26
Tucson AZ
It may have come up a time or two.
Ford Bronco Windshield washer not working -- no fluid coming out IMG_1076
Discusman68
Discusman68
Travis Bates
Ohio
I was afraid to let it run to long and risk burning motor. I’ll try it!!
QUOTE="harpo, post: 2023118, member: 3323"]
[/QUOTE]
atimberwolf
Ford Raptor
Guess I'm in this group now. Non-functioning about a week ago, so I filled the reservoir. It worked that afternoon. Now a week later, I gave it a shot and nothing. Guess I'll have to see if shutting off and back on "fixed" anything.
Roger123
Roger
VA Beach, VA
Our BL has done that once in 20K, just stopped working. I let it go for a bit and for some reason hit the rear washer and everything worked fine. I thought it was just some random Ford Gremlin.
Headsong
I nearly never use it, but yesterday it took a few tries. Maybe just needed some priming...lol.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
