Yakima EXO System on a Sasquatch Badlands
JediMcMuffin
Tommy
2021 Bronco Badlands
Would the CURT hitch be closer to the OEM hitch or the draw-tite?
Gtrekker
Gary
Here are daytime pictures with the gearlocker installed as well. I don’t have an image of it with the gate swung open fully but when it is in the locked position outward I can open the gate fully
Thats a nice setup!!! Could you provide gear box & rack info? Thanks...
Gtrekker
Gary
Hazard
Hazard
Kevin
Nissan 350z, Mitsubishi Lancer, Range Rover LR3
Hazard
Hazard
Kevin
It’s the Yakima exo. The only part that isn’t part of it is the drawtite hitch. I included part numbers as well in my original post
Gtrekker
Gary
Thanks! i went to the site and checked it all out. I have the hitch and extension.
JediMcMuffin
Tommy
How does one calculate a weight limit for this setup?
edit: with that in mind what type of off-road abuse can it handle?
Hazard
Hazard
Kevin
Extensions have their own tongue weight rating but usually it’s half of whatever hitch you’re using according to the shop that assisted me. In my case. Drawtite is 675. The extension cuts it to 337.
Personally, I take the exo off when I go off-roading as I like to rock crawl and I feel it wouldn’t clear if I’m climbing.
Hazard
Hazard
Kevin
E trailer . Com also has bundle packages for the exo. They list the full weight for any setup
Quick
CT
23 Bronco Raptor
I tried this setup this weekend. It did "work", but was far less than ideal. The hitch is really heavy and caused the rear end to sag a fair amount - though I only had it loaded with 4 skis, a snowboard, and the box only had 4 ski boots and poles in it.
I'm still looking for a roof rack to run my rooftop box with, but this works well enough for now.
skhubbard93
Saratoga NY
'21 Badlands, '01 Z8
If you're more interested in putting ski stuff up top, this option might be preferable to the Ford roof rack:
https://www.bronco6g.com/forum/threads/new-roof-rack-option.35724/
Skis and snowboards don't weigh much, and this would keep them close to the roof for less airflow disruption. It would also keep your first two roof rows removable. I have the Ford rack; it carries more, but if your goal is to carry just ski stuff, this might actually be better.
Quick
CT
23 Bronco Raptor
Thanks. I want the skis in a box though. I don't like having my bases/edges exposed to road salt and grime (as they were on the way home this weekend). That rack would mount the box (and any skis) so that they would be hanging off the back and unable to open the rear glass.
I would love to find a Ford rack if I could. Had a dealer cancel my order for one just this morning.
skhubbard93
Saratoga NY
I hear what you're saying about road salt. I continue to have that concern. The thing is, a box won't fit through my garage door while the rack does. And as long as the roads aren't soaked with salt water, not much of it seems to get up that high. But yeah, if you really want to protect your skis, an open rack is not the way to go.
JediMcMuffin
Tommy
Thats not much weight at all really. I'm skeptical even lightly loaded this thing would survive the fairly severe jostling it takes to get to some of our campsites. My thought was to get the gearbox.
