Easy installation on both. The Zroadz pocket lights are not extremely bright but better than nothing.
Mine came with a relay and switch. I just cut it off and wired it to the aux power lead and grounded the other wire.I ordered a light bar from Zroadz. Does their wiring harness connect easily to the built in aux wiring?
You should be able to, the wiring is plenty long.Wonder if you can get swap out for a different pod and use same wiring?
