⚠️EZ-Lift Soft Top Assist Damage⚠️
Status
Not open for further replies.
Jelly81Raider
J
OHIO
FORD
Regarding the soft top alignment - my top was not seated properly. I believe it’s supposed to sit flush on top this pin sticking out. Mine was not seated flush on either side of the top. Definitely worth checking your top alignment bolts even if you didn’t buy this product.
Just wanted to circle back on this. See screenshot from owners manual regarding soft top alignment. My top was off the alignment pins 1/2” on drivers side an 1/4” on passenger.
Ford Bronco ⚠️EZ-Lift Soft Top Assist Damage⚠️ 50792EF2-B0C5-4313-A6AA-2EAC4F09F9F1
Jelly81Raider
J
OHIO
FORD
Also wanted to say - there’s certainly a lot of pandering to venders that we’re all aware of, but from the jump on this issue it was pretty clear @IAG Performance wasn’t totally at fault here. The tops were slapped on @ factory and mis-aligned (in most cases I’d bet), so check your alignment pins and then thank IAG for their support and responsiveness. They are “making us whole” for an issue for which they are not fully to blame. End of the day, it’s a paint scratch on a vehicle that some will try and drive up a mountain, jump off a dune, or ford a river (pun intended). Small potatoes.
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
The paint seems to be an easy-ish fix but the potential overstretch would be a greater concern.
Man, I really wanted this product but am likely to wait it out. Great concept but possibly more variables in play than was realized.
See post 306. There isn’t an over stretch issue ;)
IAG Performance
JJ
Westminster, MD
This is great feedback! I’ll be sure to add to our new install video
Panmort
22 Outer Banks Bronco
Are you aware if there's any guidance in the manual or elsewhere for adjusting other points of the soft top, such as the front / middle?
JRS993
Joe
TN
Subaru
I installed the struts last Sunday. Put the top completely down and went for a twenty minute drive. Kept hearing a tapping sound that was new. I had my son drive and I went in the back seat to listen for and locate the new rattle. Once home, we put the top up and my son saw the driver's side roll bar had that tell tale sign of rubbing. So we got hit by it right away and twenty minutes was enough to rub the paint off. I received the email from IAG before I could reach out to them. New part is estimated in 5 to 7 business days per an email received today.
1Five1 Garage
florida
Bronco Big Bend, F350, 4Runner, 52 Ford F1 RatRod
When we installed the struts we came across some things they down tell you during the install. Items to look out for and the placement for the washer, IMO, is wrong.
They are sending replacement brackets to any previous buyers which is a good thing. But so far clearance isn't an issue for ours after a few adjustments.
AZ_BRONC
Tempe, AZ
‘17 4Runner, ‘16 BMW 328i, ‘96 Stang GT, ‘19 Mini
Helpful, thanks!
22OBX
Bryan
Hartford, AL
@IAG Performance received my revised Strut Brackets today. Thanks for getting this fix out quickly!
Calm horse
MO
Georgia
17 f150 king ranch
Just received my bracket as well....regardless of what this mod does or does not do....IAG gets a huge thumbs up from me...will definitely purchase from and support any company that acts as quick and professional as IAG....I look forward to getting more products from them.....if only I had my damn bronco to put it on!
BroncoBill44
Andy
Raleigh, NC
No comment
Waited until I received the updated brackets to install! Got them today. Love it! Thanks for sending the updated brackets. Good work!
TheKim
Kim
This is absolutely how a company should deal with this kind of issue. Once the issue was discovered, proactively reaching out to all customers, and not just the ones complaining.
Nothing but highest praise for IAG after this.
Moto26
Tucson AZ
Has anyone installed the new brackets? Can you share your experience with the fixes?
@IAG Performance thank for you for taking care of this so quickly and being open to feedback...
Uh, yeah…
amccue90
Andrew
Illinois
2021 Badlands
Uh, yeah…
Didn't realize there was any indication of an installation here.
Just confirmation of receipt.
Guess I got to read between the lines.
Status
