⚠️EZ-Lift Soft Top Assist Damage⚠️
Status
Not open for further replies.
Razorback
Bill
Dallas
Lincoln MKX
Has anyone installed the new brackets? Can you share your experience with the fixes?
@IAG Performance thank for you for taking care of this so quickly and being open to feedback...
I just got mailing notification of the new brackets. Should have them in a few days.
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
Same. Now all I need is for Jack Cooper trucking to deliver my bronco...
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Does anyone's struts have this play in them? I was just wondering if this is normal and could it be the noise folks are hearing?
BisonInTexas
Craig
2018 Ford Explorer Sport
I noticed the same on mine and it has the same sound as the rattle I hear occasionally. But I’m not sure if it is the cause or not. I’m going to try and do some troubleshooting once I get the new brackets.
ICUGAZN
Kevin
2019 Raptor
Ugh! My band broke.
amccue90
Andrew
Illinois
2021 Badlands
Ugh! My band broke.
Yea I had a bad and frustrating time with the band. Ended up using a small ratchet strap. I also ripped off some plastic tabs off my rear window which almost caused my head to pop
ICUGAZN
Kevin
2019 Raptor
So I went back to the original instruction video where he did the brute force method if the band came off and the strut was expanded. Good thing I worked out this morning. :cool: This was the replacement bracket install. All done now. :)
CKXVII
CK
F-150
Are these the old brackets or new brackets? I‘ve only taken my Bronco out once with the new brackets installed and the top fully on…and so far, I haven’t noticed the same sounds occurring.
HemyPowered
West Chester, PA
Range Rover Sport, Land Rover LR4, BMW Z4
Good catch- that is what mine sounds like
ICUGAZN
Kevin
2019 Raptor
I'm just curious if it could be making noise when driving. if you grab just your piston and wiggle it. Is there play in it? I'm not sure if its just by design or not.
Moto26
Tucson AZ
When my rear hatch is open, I can wiggle the strut and hear a rattle. It’s not the closest tolerance in the world. But when the hatch is locked down, the struts are partially compressed, so it seems odd that they would still rattle like that. I suppose it’s possible.
If you’re hearing rattles, sometimes the only way to locate them is to have someone crawl back there and listen while you drive, preferably on a bumpy dirt road. My mom’s Subaru Forester had a rattle, and when I rode back there I discovered it was coming from outside the car, and it ended up being a loose license plate mount! 🤪
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
If you grab the strut body and wiggle it will make some noise. But on the flip side of that so do the factory Ford struts. The factory one on the driver's side of our Bronco is super loud, with or without the EZ-Lift system. We rode around with one of our guys in the trunk to try to pinpoint some noises. Neither our struts nor the factory Ford struts actually moved while driving to make any noise, but we did hear some clicking or rattling noise that we pinpointed as the plastic clasp at the top of both side windows. We duplicated this noise both with and without the EZ-Lift as well to make sure it wasn't a byproduct of our system.
amccue90
Andrew
Illinois
2021 Badlands
Hmm what clasp and is there a way to secure?
Pseudoko
Vince
Chino, CA
My 2 Feet
Status
