Chrism81
chris
connecticut
Mazda
Dammit, they really came out swinging with accessories. Looks Like I am going to end up spending a lot more money now
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
I know some people are excited about those manual locking hubs, but my advice is avoid them.
They will not add any longevity to the existing drive train and are an additional failure point.
Regular scheduled fluid changes on the front diff is all that is needed
Erock
US
2018 F150 Alpine edition
DIY, no problem, we got this...
as funny as this is, I understand their pain. I put a 289 in a mustang II when I was a teenager, however, I was patient enough to find the special bellhousing that would let it move back far enough to fit properly.
on another note, I’ve got a buddy who has a Mopar 360 in a 2wd Samurai With the radiator and fan mounted out front. Looks slightly better than this though since he made brackets instead of ratchet straps... lol
5280Bronco
Denver
It looks like the replacement aftermarket in the rear and removed in the front... I don't like that. It's what keeps me from lifting/modifying my ranger... that's a BIG safety feature. desparately need to see how they handle these on the sasquatch.
Sasquach just removes them at the factory and calls it a day.
Ryuk
PA
One more reason to get SAS from day 1
Insurance can't deny a claim if it came that way from the factory.
Well they can, because insurance companies suck, but at this is proof it was not done by the owner
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
There's 4 cameras for the 360 correct? Front, rear, and 1 in each mirror. I'm pretty sure the mirror mounted cameras give the tire shots not the front camera. If that's the case then the front camera could be mounted elsewhere with an extension cable.
I'm not referring to the tire view - you're right that those cameras are in the mirrors.
I'm talked about the view from the front camera with a white overlay of tire tracks. These tracks move as you turn the wheel to show you the path each tire will take. If the camera is moved without some sort of adjustment, those tire tracks won't be in the right place.
Lowcountry Bronco
William
South Carolina Lowcountry
Got it ... yep, that'll be a problem, not sure if it can be reprogrammed or deleted out sure someone will figure it out.
Ford Bronco 🎥 4WP Releases Its Bronco Black Diamond Build Pics & Videos 1617370808487
Ryuk
PA
I would think raising it would not cause an issue with the left to right, especially since the mirrors also see the tires.
But I could be completely wrong
Felix808
SRV CA
I keep watching the suspension work in the videos and to me it looks like it is too stiff. Very little compression until the biggest of hits. This might be because everything is being done at speed & how the valving is reacting. I'm not as interested in bombing down trails, catching air & such. I'm curious as how the suspension works at lower speeds crawling through rocks & ledges.
Thoughts :unsure:
395N
Orange County CA
22 Jeep Rubicon XR
Thoughts :unsure:
I agree.
I does appear stiff.
I'm with you. I want suspension that will lend itself to slow crawling through technical terrain. Basically focused suspension under 25 MPH when the sway bar is disconnected is the sweet spot I'm after.
Felix808
SRV CA
I agree.
Yep, looks like I'll be waiting a while for the beta testers to figure out what works best out there. I would like a little more lift to get the body up out of harms way & fit 37's, but it would be a real shame to toss the great suspension that really works for one that doesn't ;)
vrtical
Doug AI
GSMNP, TN
Fords
SEMA 21 I may not leave the truck section where the Bronco stuff will be, gonna be epic.
395N
Orange County CA
22 Jeep Rubicon XR
Same page Brother.
Efthreeoh
Hummer H3T
That fender flare delete will be the #1 selling item they have
Yeah, but the bolts look goofy to me. You could injection mold the flare with plastic studs that feed through the fender holes then fasten a sheet metal body nut on the stud.
