- Phil
- Jul 21, 2020
- 41
- 4,312
- 14,283
- IN
- Website
- www.ruxerparts.com
- Fords
- Badlands
Did they provide any theories of how the air filter got soaked or found where the water entered the box? If not, this problem is likely to happen again. This assumes the has not gone through any high water since you've owned and went through anything that would induce a lot of splash from the bottom. Since the intake is under the hood and not directly exposed to rain, stuff that might enter through there should show some traces of water stains on the radiator support trim. Is the hood seal present and installed correctly? Was the vehicle detailed at any point from time of delivery to when you started the trip? Meaning, could someone have sprayed the engine compartment down getting water into the inlet.
Too many unknowns but the point is if the cause of the water getting into the air box was not found or fixed, you still have an issue.
