Agree on this - Keep us posted if you pull the trigger on the new design and how it stacks up against the Ronin. Looking forward to hearing your (hopefully positive) feedback.I am considering being a guinea pig on the new UPR (https://www.uprproducts.com/upr-for...for-mustang-f150-raptor-edge-explorer-bronco/).
The double o-ring is appealing because it will seal better (still cannot believe the Ronin weeps, but it IS pretty sloppy on the fit) and the metal tabs on the other UPR design although secure will ultimately result in wear if removed frequently.
The other benefit is the new model may drain a bit more oil from the pan due to the design allowing oil to flow from the inner diameter versus the outer:
This:
Versus This:
