Tarheel_Wes
Wesley
FJ
Has anyone found how to make the switches always on rather than switched with the key. I've been searching the forums, but coming up empty.
Bumping this back up for this question. I have some interior lights that I added to aux 4.
Ideally, I’d like it to always be hot rather than depending on ACC…..for things like camping and stuff.
Anyone done this?
Tarheel_Wes
Wesley
FJ
Yes I was able to this past weekend. I'll snap pictures of it and provide the proper pin/harness location. One wire feeds power to switches 1-4 and the other wire feeds power to switches 5-6.
Oh I just saw this
See my post above
I want to make my Aux 4 always hot, if it’s fairly simple.
2Jeeps&PatriotX1
Denver, CO
Oh I just saw this
See my post above
If you want switch 4 to always be hot, switches 1-3 will as well. No way around that. You can’t have switch 4 hot and not 1-3.
Same goes for switches 5-6 however they are not tied to switches 1-4. You can’t have switch 5 hot without 6 being hot.
Tarheel_Wes
Wesley
FJ
Ok cool.
I’d be good with 1-4 always being hot.
Tarheel_Wes
Wesley
FJ
And thanks. Any help on how to do this would be much appreciated.
firefox33
Lincoln
I’m a little old school here and trying to understand the Aux switch wring. Attached is a “old school” drawing of I would typically connect a switch to a device. Can someone please show me how this relates to a Aux switch wiring. Hope this makes sense.
Thanks.
BroncoAW
Adam
Plymouth
F-150 Fx4
Not sure if this is your video but I found this last night on another thread and you saved me so much time, thank you. I ended up cutting the wire along the rear passenger running board like you (?) suggested, popped on a butt connector, ran a new wire under the rear folding storage board and into the jack cubby to wire my rear bumper lights in.
Ford Bronco 2021 Bronco AUX Switches Wiring Diagram, Video, Discussions FECEF8A8-5A16-4B34-A507-270B4835F31A
Did you just wire in both lights into the supplied wire? And did you just ground it under the hood? I’m about to install a new bumper that has lights and trying to figure out how to splice in the supplies harness with the aux switch
campbebc
Ben
Boulder, CO
2017 Ford Focus RS
I wired both lights into the wire that I ran off the supplied wire (same as the guy in the video). I believe I grounded it out on an existing ground that was in the trunk area, you don’t need to run it up to the hood.
xusarmy
Todd
TX
2021 Ford Bronco Outer Banks
Hey did you ever post your pictures of how to make these to "always on"?
akturbo
Seattle Eastside
'21 Bronco, 3500HD Chevy, Rav4Prime, Turbo Skidoo
This! I posted a new thread asking this question and it came up empty. @2Jeeps&PatriotX1 , we're all very interested in what you did! This is literally what I am working on today, I want my dashcam and Midland 275 switched always on.
akturbo
Seattle Eastside
I figured out the Upfitter relays are in the BCM, then figured out the BCM is below the steering wheel. I'm close, thinking I need to find the Green wire that is leading to switch E and F. Open to ideas!!
Edit: I never did find the green wires from the BCM, nor how to get into the Battery Junction Box. So I tapped in at the overhead console.
Ford Bronco 2021 Bronco AUX Switches Wiring Diagram, Video, Discussions 1653003489642
Ford Bronco 2021 Bronco AUX Switches Wiring Diagram, Video, Discussions 1653003499879
Ford Bronco 2021 Bronco AUX Switches Wiring Diagram, Video, Discussions 1653003514880
Ford Bronco 2021 Bronco AUX Switches Wiring Diagram, Video, Discussions 1653003547563
Gtrekker
Gary
NJ
AUX Switch Wiring Diagrams:
By @swooshdave
🎥: by Bronco Nation
How to access, connect, and use the auxiliary switches in the 2021 Bronco.
Hey, I've used several aux / uplifted switches and added a dongal to my rear view mirror. Mirror power turns off vehicle is shutdown.
The issue I need support with... Can I change an aux switch to be hot / live with power even with accessories off? My in car camera has 360° parking monitoring but needs power 24/7.
I can run a hot lead to the camera but thought connecting it to an aux switch would allow me to turn it off when parked in my garage.
Thoughts..... thx!
akturbo
Seattle Eastside
Austin Bronco
Matt
Austin Texas
Triumph Street Scrambler
Thank you so much for the info! I am looking to add aftermarket heating to the passenger seat, for my Wife. What would be your recommended method for wiring to an aux switch? My limited knowledge tells me you could connect to the wires in the glove box, but it also appears you have to jump the wires there, to the fuse box, to access one of the aux switches. I am considering an aux switch, because other than adding the Oracle illuminated BRONCO letting, and Rough Country lights to the modular bumper, I don't see adding much more. I will let the vendor connect the wiring, I am simply trying to give them as much info as I can, to help simplify their process.
Thanks so much!!!! This is exactly what I’ve been looking for.
akturbo
Seattle Eastside
NP. Not sure if you saw my last update, I still need to figure out the power feed, just planning to do run a fused power run. That yellow wire is on a delayed relay that turns off after awhile. It was working every time I tested, even over night, I open the door and the relay turns back on. I may still use that line for LED interior lights, just as a sense to switch a relay.
