I wonder what "High-Clearance Suspension" (Option on all but the Wildtrack and FE) is especially on the Badlands? More than a BL suspension?
Looks like the 10 speed auto is standard on all 4 doors except the Badlands, so I read that as the BL is the only 4-door where you can get a 7 speed manual.Is this basically saying that the 4-door models will not offer the manual transmission? I don't see the option for 4-door manual transmission listed anywhere.
Just an FYI. Electronic-locking Front and Rear Axle comes standard on WildtrackI made up this spreadsheet to make it easier to compare models and see what options are available for each. I hope you find it useful.
PDF download link: 2021 Bronco Options Chart by Trim & Model (by TUNGSTANG at Bronco6G).pdf
Golly, guess we will just have to wait and see what is offered in the build/price, but that would be a huge disappointment.Looks like the 10 speed auto is standard on all 4 doors except the Badlands, so I read that as the BL is the only 4-door where you can get a 7 speed manual.
YOU THE MAN! Great work.Thanks for the positive comments Bronco Fans! I used Office 365 Excel to make my sheet but didn't realize my format would need to change when it was uploaded. The funky colors are a result of my theme not translating very well to the xls format. The process was literally cut from ford.com and paste into Excel, so human error was a factor in some of the errors being pointed out.
The mods were kind enough to convert this to pdf so you could download without fear of getting a virus which is awesome. I encourage you to call out any other errors. I don't want to burden the mods with making file corrections and converting the files again.
Some of the options not listed, such as garage door opener, were only listed in the Package Descriptions I screenshot at the bottom of the sheet. I didn't want to murky the waters by trying to add them above. Have a great weekend!
It looks like you can get the 7-speed on the 4-door, per Ford.com specs section.Is this basically saying that the 4-door models will not offer the manual transmission? I don't see the option for 4-door manual transmission listed anywhere.
I think the First Edition and the Badlands will have the same floor systems. Rubber with drains can removable carpet. Maybe I am wrong.I didn't realize the FE would have vinyl floors. Makes my decision to go to a Badlands even harder now.
I've talked to some Ford people about this. It should have the same tow rating as the other trims because it is mechanically identical. However, it doesn't have a factory tow hitch/package. Therefore, there is no tow capability. Put a hitch on it and I'm sure 3500 lbs will be no problem.Excellent Chart!!! I noticed under "Towing Capability" for the Base model it is blacked out. Is this correct that the Base model is not or cannot be setup to tow?
Well, that was my plan when I reserved it... Fingers Crossed!wow... so many "optional" things I want with the badlands.... expensive
I think you guys with the first edition are going to see some discount with everything it comes with
We will see I guess
