I agree!100% and if there is a base on the lot I would bet it has every option available picked.
I'm thinking along these lines as well. The Ranger has a rear locker as an a la carte option, so hopefully they offer at least the rear if not both lockers on the Bronco. As far as gearing, I could be happy with the standard 4.46 if paired with the lower low range of the advanced T-case, but if Sasquatch is offered with manual, I'll most likely go that route.As I think about it and read through this thread, I could probably be happy enough with the Base, 7spd, and 4.70 lockers. That is my low buck dream build. Not holding my breath on lockers being a la carte though....
The price difference between the 2-door Base and the 2-door Big Bend is not worth theprice difference. I'm pretty sure I can add most if not all of the upgrades for less that $4,700I have to put numbers into a spreadsheet and/or chart to make sense of them. The way the 4 door price curve compares to the 2 door pretty clearly shows that the 2dr base was purposely held low, and the 4dr FE was inflated.
It's $7K, differences are in the attachment.Why is the WT $10k more than Badlands? (4 dr)
Thank you!It's $7K, differences are in the attachment.
So, Base 2dr...best bang for the buck
Thanks, science.
