BroAD
Adam
Illinois
2012 Ford F-150
Pretty bad when not even the official forum of the Bronco that is owned by Ford knows what’s going on with this vehicle.
I was looking for some type of acknowledgment but nothing... it’s like the first video never happened.
BroAD
Adam
Illinois
2012 Ford F-150
Why does the title of the video say "Incorrect, do not post?"
Because Bronco Nation posted a video yesterday that they recalled and reposted because of an error. Updated video corrects the error about the Trail Turn Assist requiring the 2.7L, which was incorrect.
t3n2and4
VJ
Washington
www.instagram.com
Badlands, F150, VW CC
Maybe I’m way deep in a Friday night, but were folks expecting their rock crawler to tear up pavement? I wasn’t.
I was looking to avoid that bronze dash mostly. The swaybar is overkill for my level of noob.
t3n2and4
VJ
Washington
www.instagram.com
Corrected video from Bronco Nation... I guess someone is listening:
Clarifies the misinformation about Trail Turn Assist requiring the 2.7L.
@Administrator can this be pinned to top of the thread since the old video says “INCORRECT“ now?
Efthreeoh
Hummer H3T
I can't imagine I would ever be bothered to change the drive mode. You can manually engage the lockers and the transfer case...this is completely useless.
If you are going with a manual transmission, having the GOAT system that adjusts the throttle actuation is annoying because it throws off your learned throttle/clutch coordination. I have a sports car with sports mode. It is meant to increase the throttle tip-in (makes it more aggressive) and change shift points for the automatic transmission. That's all fine, except I have the manual transmission version of the car, so while the sport mode increases the aggressiveness of throttle input, my left leg is calibrated to the normal throttle mode. You end up slipping the clutch and drive like a noob.
During trail riding, I can see this as problematic. Good clutch control is key to not breaking stuff or hitting stuff.
AzScorpion
AzScorpion
2019 Ford Ranger SuperCrew Lariat 4x4
Beach_Bum
St. Augustine, FL
I just edited the OP with the updated video.
Good to get the correct information up front to not confuse others. Of course, anyone that wasn't following this thread will be confused by the subsequent replies that were referencing the incorrect video.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Can a person change goat modes on the fly, is there a speed limit you have to stay under? Are there safety features in place that won't allow shifting into 4H/L doing 60 on dry pavement...? Thanks for the info, sorry if it's posted on here somewhere but I could not find it in search.
Dubfound
New Hampshire
Audi’s
Has to be I assume. I need to know this because my Boxer loves to ride shotgun with her paws on the center console. I can just imagine her dropping my bronco into 4 low on the highway. Hahaha
samanator
Pompano Beach FL
Jaguar F-Type R
If the only thing different between a WT and a BL if you get Sasquatch and a 2.7 in both is the swaybar disconnect in the BL. Why can't we just ask Ford to include Sport in the BL? Seems like an oversight since all others have it. They have listened to some of the other requests, and it appears all of the rest of the things are there to allow it to work. Otherwise, make the MGV and wash out interior be available in the WT. Sand is just too hard to get out of the carpet and we live in wet bathing suits here. I want a BL more for the interior than the disconnect on the swaybar. This interior tied to the model is getting ridiculous. So here are two options to present to them. Technically the Swaybar disconnect should just be an option on other models and with it's inclusion Rock crawl should come with it if Sasquatch equipt. Make that three while adding Sport to all models. We're in delay anyway. Should be easy to code this since all the main work is done already.
robepa
Paul
West Seattle, WA
www.instagram.com
2022 Bronco, 2006 Tacoma, 2020 4Runner
I want custom GOAT mode(s) that I can select the different custom configurations. Configurations I might want are
  • Overland mode to maximize the range: eco engine/trans setting, swaybar disconnected and 4A
  • Sport Mode: Baja engine/trans mapping and 2WD or 4A
This could be like BMW's M modes where you can change the default settings and/or additional custom modes
Hoofnmouth
mark
N ca
ford focus st
So cute turn a dial instead of another stick in the floor.
t3n2and4
VJ
Washington
www.instagram.com
BroAD
Adam
Illinois
2012 Ford F-150
Just had to made yet another correction to BN this time on their video highlighting Bronco Sport. Bronco Nation stated in the video that Trail Control is for speeds less than 5 mph... come in Bronco Nation, get the facts straight that your sharing with the public.
