BroncoBoy22
Laker Land
'11 Mustang GT 5.0
M2DZ-19980-D (from a 2021) is impossible to get right now and on a massive backorder
N2DZ-19980-N (from a 2023) is much easier to get and will probably only take a few days
I can confirm that the 2023 part number N2DZ-19980-N will swap right over and work perfectly after being programmed. (These part numbers are for Heated Rear Window, Heated Steering Wheel and Heated Seats)
Forscan is all that’s needed for programming right?
Ducati1098
I would assume forscan can program it no problem, however I don't know 100%. I work at a dealership, so I have access to FDRS for all my programming.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Ah gotcha thanks! I assume my dealer would prob charge 1-2 hours labor for this then. Wish your dealer was close to me then I could be sure they knew how to do it 😂
a_Panda
a_Panda
Rochester, NY
2022 Bronco, 2020 XC60, 1978 124 Spider
While your mileage may vary... Forscan worked perfectly for me.
Ducati1098
You could always try it with forscan and if for some reason it doesn't work, you can always purchase a 2 day license for FDRS. I think it's only $50
Riverjeep
Bill
Va.
Wildtrak, F-150
If it works like my F-150 then yes, you simply install the module and then hit Load AB for that module. You will need internet access to accomplish this as Forscan gets you load as built data from Ford b
Riverjeep
Bill
Va.
Wildtrak, F-150
Why do you suppose Ford doesn’t just use the new part to supersede the old? Is this normal if they are identical units?
Ducati1098
They may be in the process of doing that, but honestly I’m not sure.
It certainly is not normal if they are in fact identical. From what I can see, there is definitely no difference at all between the 2 though 🤷‍♂️
swooshdave
Portland, Oregon
Mustang
My guess is that they sourced different chips for the 23s. Some that are easier to get than what they had in 21 and had to drop in 22.
Ducati1098
Yeah that would make sense. I’d say that’s a pretty good guess.
Riverjeep
Bill
Va.
Wildtrak, F-150
Yeah, I guess as long as it works, I'm going to pull the trigger.
Riverjeep
Bill
Va.
Wildtrak, F-150
Have you changed yours out, I just noticed we have the same build color and all, except mine is a 4 door?
Ducati1098
Oh yeah, that’s a funny coincidence. Yes, I switched mine out last week. Everything works perfectly and went very smooth.
Ford Bronco 2022 HVAC Temperature Display Dial Retrofit DIY & Part Numbers -- Install Success! 3CE82C76-5E12-41CE-944C-68E2A4300524
Riverjeep
Bill
Va.
Wildtrak, F-150
Perfect, looks great, I just ordered from Fairway Ford as they allow me to use Ford pass Points!
