33 to 35 on a 2D Badlands non Sasquatch - New Spare mount and tailgate upgrade required?
KAnoe
Keith
Maine, USA
Ford Ranger and Subaru Crosstrek
Going from 33 to 35 in on a 2D Badlands (non Sasquatch), after a 4in lift.
Do I need to upgrade the tailgate and spare tire mount? Thinking no because it could have come with 35s if I got the Sasquatch.
thoughts - Thanks
Shoresy
Matt
Land cruiser, focus st
I did the same and tire fit fine. The 3rd brake light does touch the tire but didnā€™t seem to be too much interference.
I have the GY 315/70 so if you go with a larger diameter then may start to create a problem.
KAnoe
KAnoe
Keith
Maine, USA
Thanks Shoresy
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
thoughts - Thanks
You should be perfectly fine. Good luck!
TXBronco72
Magnolia, Tx
F250 / 4D ā€˜23 Wildtrak
I went with the Hammerbilt tailgate reinforcement just to be safe. Also have the RC light extension. Iā€™m probably going to take that off soon and do the break light in the spare tire for better visibility out the back window.
Ford Bronco 33 to 35 on a 2D Badlands non Sasquatch - New Spare mount and tailgate upgrade required? 8D43250B-884C-4FD9-9BA7-DB3AA2A02504
Ford Bronco 33 to 35 on a 2D Badlands non Sasquatch - New Spare mount and tailgate upgrade required? A6DA803F-25D0-4B1C-8091-5D22C4E0AA89
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Those tailgate reinforcements are ugly and totally unnecessary
ā€˜you will need to trim the rubber bumpers about 1/4 inch
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
Any rubbing?
HoosierDaddy
Indiana
I went from a base Base to a 35x11.5-17 on a 17x8.5 +35mm wheel.
As stated above, just barely kisses the brake light, seats against the door bumpers like it was made for it.
Ford Bronco 33 to 35 on a 2D Badlands non Sasquatch - New Spare mount and tailgate upgrade required? 1667088650333
Ford Bronco 33 to 35 on a 2D Badlands non Sasquatch - New Spare mount and tailgate upgrade required? 1667088738984
Ford Bronco 33 to 35 on a 2D Badlands non Sasquatch - New Spare mount and tailgate upgrade required? 1667089405219
Ford Bronco 33 to 35 on a 2D Badlands non Sasquatch - New Spare mount and tailgate upgrade required? 1667089440859
Shoresy
Matt
Any rubbing?
Nope. I did put 1.5ā€ hub centric wheel spacers to clear the suspension bits and plan to do a 1.5ā€ front level this winter. Run some pretty good trails without any rub issues.
KAnoe
KAnoe
Keith
Maine, USA
Going to go with this. I like the look of it. Looks like you needed to black out the bolts?
TXBronco72
Magnolia, Tx
Yeah I did. I would call Hammerbilt before you order to see if they have the black hardware. I colored the bolts and figured I would go back at some point and change them out (I wasn't patient enough to wait :))
MK0412
NH
Accord and Bronco
How is the HB holding up? Rust etc? Also how is the black hardware doing? Pain pen used?
TXBronco72
Magnolia, Tx
HB has held up very well with no issues. I haven't noticed any rusting but have to admit that I haven't done a detailed inspection either. (nor have I bolted anything to the accessory bracket)
I used a permanent marker to color the bolts and it's actually lasted just fine...but my bronco doesn't sit out in the weather full time. If you use a permanent or paint marker, just make sure you color the bolt heads before installing, then you can touch up after. Once installed, it's impossible to color some of them 360 degrees.
