You read my mind. Very timely and I plan to do the same thing. Please post if any issues. Maybe rub at full articulation on the trails......ThanksThey are Factory Big Bend wheels
The SAS package has beefier axles, which really makes the whole package pretty nice for the money if you think you might want bigger tires and/or lift later.Ummm, what do you mean? as opposed to what other axle?
OUTSTANDING! Thanks for sharing all of this!!!Alright guys. Special thanks to Mathew and Jay at Two Rivers in Nashville, they have been great and very accommodating
It only has a stronger ring and pinion in the front, not the rear. Also, unless I am wrong, I thought the axle shaft diameter was the same for both the m190 and the m210.The SAS package has beefier axles, which really makes the whole package pretty nice for the money if you think you might want bigger tires and/or lift later.
Did you have your speedometer re-calibrated?Tire sizes are 285 70r17
Tire height and full compression.So, if my math is correct, the LT315/70R17 Mud-Terrain (M/T) Tires ordered on my OB are wider, and 34". Why wouldn't 33's fit? I'm sure I'm missing something here.
I think the axle shaft question remains unclear. Rear axle is the same either way. Ring and Pinion diameter size and swap to iron housing on front (probably larger bearings as well?). I was on the fence BD vs BL but the front axle is the weak point with larger tires. Ford doesn’t spec anything larger than 265/70/17 on the 190 front (probably fine for most light/normal use with the 285/70/17).It only has a stronger ring and pinion in the front, not the rear. Also, unless I am wrong, I thought the axle shaft diameter was the same for both the m190 and the m210.
@Jb7 congrats that's my exact build. I can spend $ for winter tires instead of buying new rims to fit the 285/70/17I believe so, although I opted for the 4.27 rear locker so I should have zero problems in relation to gearing
Ya, I only want to run 33's or 35's at most. If I were to break a front open differential (which is theoretically possible), then I would just find the first wrecked BL or WT I could and just snatch the diff out of it. I could then make it a manually activated locker... Seems like a reasonably straight forward swap. I don't see this getting any extreme use, but I certainly could see swapping in a locker or even a torsen of some sort.I think the axle shaft question remains unclear. Rear axle is the same either way. Ring and Pinion diameter size and swap to iron housing on front (probably larger bearings as well?). I was on the fence BD vs BL but the front axle is the weak point with larger tires. Ford doesn’t spec anything larger than 265/70/17 on the 190 front (probably fine for most light/normal use with the 285/70/17).
