hotrodtim
TIM
2019 EXPEDITION,2009 F150,2003 LINCOLN AVIATOR
Tough to say because i changed the tires and perch collars at the same time. With the tires it rides a little rougher at low speeds with 53 psi in the tires.
Nicely done , I have a question for you. Do you happen to know what the total height is now with the modifications ? Curious to know if it would fit into a standard height garage door? If you could give a highest point spec . Thank you.:cool:
John Auer
Captree Island, NY
Lincoln Nautilus, Ford Expedition
Love the painted flares. I'm seriously thinking of doing the same with my OBX with Sasquatch. My unit may come so late that I'll end up with a '23MY. Maybe Ford will make Sasquatch painted flares an option, and finally offer the painted modular top. I can dream, can't I?
AK SNO RIDER
Ty
Alaska
Oh man, it's like you're reading my mind here. Painted flares, bronze wheels and 37s are exactly what I've had in mind for my RR FE
Bronco Pilot
Matthew
Las Vegas
2006 BMW M3, 2018 F150, 2018 EA330SC
Looks awesome !!
snownow
Robert
SO cal
2013 expedition
Well done, very nice looking. Was not a fan of the painted flairs until now.
MannyG20
Ted
F-150
That’s the best looking Race Red I have seen. Wow.
WLDBST
Tucson, AZ
2019 Ranger FX4 4X4
Build Details
Rpg perch collars
Fuel Rebel 6 17" Wheels (+0 mm offset)
Nitto Ridge Grappler 37" x 13.50
Painted to match Sasquatch fender flares
* Waiting on the 5th Tire/Wheel
Congrat's on the new Bronco. It looks really nice with the painted flares and wheel combo. I have 2 dr Badlands with the Sas pkg. I have been looking at that same RPG lift. On the fence bigtime about going to 37's. This look's like the least expensive and best way to go not to change the factory ride. How does in compare to factory as far as ride quality and does it hunt for gears etc.? Did your Ford dealer do the lift?
6GSooner
F250
Build Details
Rpg perch collars
She's a beaut Clark! I'll be doing same tires on my Rapid Red!
EMBronco
Tyler
Eagle Mountain, UT
F250
Build Details
Rpg perch collars
Your bronco looks great! Curious about the lift. A couple of the pictures make it look like it sits level, and a couple look like there is still a bit of rake. I know pictures can be deceiving sometimes. Is it level in real life?
Lewis_Bronco
Lewis_Bronco
Shelby
Fayetteville AR
Its pretty close to level, RPG says 2.25 in the front and 1.5 in the back is what it adds.
Yes I had the Ford Dealer do the install. It was pretty far out of alignment once installed.
It doesn't have any issues finding a gear a cruising speed but i could tell above 75 it took some more throttle.
I added sport mode with Forscan and feel like it drives best when in that mode.
Ford Bronco 37" Tires on Rapid Red First Edition Bronco w/ Painted Flares IMG_9915
Ford Bronco 37" Tires on Rapid Red First Edition Bronco w/ Painted Flares IMG_9914
Ford Bronco 37" Tires on Rapid Red First Edition Bronco w/ Painted Flares IMG_9913
Deleted member 9490
Guest
Man that's a good looking rig. I also have a RR FE and I am very interested in how the paint holds up on the flares long-term. Any concerns about rocks/debris hitting the inside of the flare causing the outside to pit or peel?
  • Like
Reactions: Cat
LSBronco13
Lee
Louisiana
Chevy Tahoe
Build Details
Rpg perch collars
You will soon be painting door handles too.
  • Like
Reactions: Cat
JeepersCreepers
Ryan
Sparta, NJ
Jeep Wrangler TJ
Looks so much better on 37s. It really bugs me how small the Sasquatch'd Badlands looks on 35s. Looking forward to doing this myself.
vzqhsg
MI
F-150, Badlands
Build Details
Rpg perch collars
So are those the same OEM flares with paint on them?
1975U15
2019 F-350 SD, 1975 Bronco
Arguably best looking Bronco on forum. Well done!!
