KrazeeEyezKilla
UT
I painted the Factory Textured ones that came on it.
What’s the texture like after painting? Think it’ll hold up well? Awesome looking Bronco!
Suke996
Bronco First Edition (Reservation)
One of the best looking Broncos so far.
Lewis_Bronco
Lewis_Bronco
Shelby
Fayetteville AR
Here is another one that we painted for a buddy, These are non sasquatch flares but still textured to start.
Ford Bronco 37" Tires on Rapid Red First Edition Bronco w/ Painted Flares IMG_8800
  • Like
Reactions: Cat
John Auer
Captree Island, NY
Lincoln Nautilus, Ford Expedition
I think any model Bronco looks better with painted flares, just saying.
vzqhsg
MI
F-150, Badlands
Are the OEM flares smooth, or do you have to sand them down, etc?? What is the codt to have this done?
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
They look great! how did you paint them or did you just drop them off at a body shop? I have to imagine that they used a filler and then a bunch of sanding to get a paintable surface. Does it feel durable?
NathanW
Nathan
FL
2021 Rubicon Unlimited, 2020 Range Rover SVR,
Not smooth. Someone else posted a thread about painting the factory flares. He said that they sanded them smooth with 400gr to prep it.
ahtussey
Abbey
Maryland
Ford Fusion Sport
Build Details
Rpg perch collars
Fuel Rebel 6 17" Wheels (+0 mm offset)
Nitto Ridge Grappler 37" x 13.50
Painted to match Sasquatch fender flares
* Waiting on the 5th Tire/Wheel
Truly gorgeous! Well done! Where did you get the striping on the bottom of the doors? I love the dual color.
'18 M2
2023 Warthog
Its pretty close to level, RPG says 2.25 in the front and 1.5 in the back is what it adds.
Yes I had the Ford Dealer do the install. It was pretty far out of alignment once installed.
It doesn't have any issues finding a gear a cruising speed but i could tell above 75 it took some more throttle.
I added sport mode with Forscan and feel like it drives best when in that mode.
Do you mind sharing what you paid for the lift + wheel mount + balance + alignment?
Granger quoted me a ridiculous amount.
MSparks909
Miles
ENC
2014 Ford F-250
Tough to say because i changed the tires and perch collars at the same time. With the tires it rides a little rougher at low speeds with 53 psi in the tires.
Ooooffff! 53 PSI is wayyy high. Drop it down to 35ish. 40PSI tops. Beautiful Bronco!
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
How tall to the top of the roof? Curious if this setup would fit in my garage.
