604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Toccoa
Isuzu Rodeo Sport
Let me know what you think and where I should improve on!
More attachment points in the rear. Your weight in the tent will not always be in the center. That will create stress on the hitch point to that side. Enough stress back and forth and you will suddenly be sleeping on a soft hill that was your soft top.
Natethegreat1979
Nathan
Western Massachusetts
2022 Ford Bronco
Hardtops are too expensive and rare. Roof racks for soft tops are weak, expensive, and only found in the states.
Made my own prototype from some scrap laying around, doesn't look the prettiest but she should take a beating.
Kinda looks like PVC, I'm sure it isn't but it kinda looks like it 😅
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
😂 Love the honesty.
I have a rigging setup in my carport to pull it off. Takes about 10 min to remove.
I plan to make the rear wider and more rounded, to open the gate.
Main reason for going with the hitch mount is strength, the dynamic load are pretty heavy for how flimsy the mounting points near the rear fenders are.
From what I understand, the hitch mount is strongest in horizontal motion, but not for vertical. My factory hitch is already sagging a little from the weight of 2 coolers on a hitch basket.
Malicar
Malicar
Jessy
Prince George, British Columbia, Canada
2022 Bronco
This is true. It is strongest on the pulling.
That sag must be open space between hitch and receiver though. Maybe the rack itself sagging some.
I've done some brutal things with structural steel, and 6065 t6 aluminum.
You could hang a car off one sideways. Pretty hard to bend a solid chunk of 2" square, or a receiver.
rustedgoat
Honda Element
I think that's a lot of weight on that windshield frame. Any shift of weight goes either front or back, you do a panic stop everything goes forward. A fabricated rear bumper with mounts on the outer edges, for the front maybe something going down toward side step. You end up with an exoskeleton type cage, kind of like what you see on forest fire trucks. "A" for effort and continue with v2 or v3.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
I appreciate the feedback!
I like your idea of going from the extraction loops. I could make it look much more suave from there. My big challenge for that is creating 90° bends with AL structural pipe.
The windshield mounts should be tied into the rollbar, it's a matter of how much the (4) 6mm bolts mounting them can take. May run a plate or bar from the front mounts to the ditch light mounts for some extra strength. The long bars sucked up to the rtt once mounted, no bend.
I would get a hardtop, but I live in Canada. It would be close to 15k CAD to get it to my house 🙃
Powder coat black would definitely help it blend in. If I can make it look nice, would be cool to polish the aluminum.
I think it depends a lot on how the front brackets are secured - if resting on the brackets and relying on the shear value of the bolts alone, it could be problematic, but if it's engaged with the bracket laterally and you get good clamping force against those brackets, it should be ok.
seanoj
Sean
Crown Vic, Porsche 911
I have been thinking about doing just this kind of project (with steel, however, as I don't have a TIG welder -yet).
I am not a huge fan of the hitch mount as only rear support. Front lightbar mount is probably okay for a couple hundred pounds of load?
Getting ideas from the options below:
Gobi has some interesting attachment points both front and rear-and an interesting tilt function (300lb max load) :
https://gobiracks.com/product/ford-bronco-4door-stealth-rack-soft-top/
zRoadz is using the lightbar mounts (265lb max load):
https://zroadz.com/i-23915845-2021-...olle-panels-for-4-door-models-pn-z845481.html
JCR is using flat bar/sheet instead of tube. (200bl max load) - Lightbar and rear quarter panel mounts have this shifted forward enough to allow cargo access (flip up of back of top):
https://www.jcroffroad.com/product/BR6RK-ST-F-4D.html
DV8 is doing something similar to JCR, but longer (no flip up of back of top) 200lbs:
https://dv8offroad.com/collections/ford-bronco-roof-racks/products/6th-gen-bronco-roof-rack-soft-top
mikeeshim
Los Angeles, CA
How about 200-300 lbs hanging off the back but on pretty bumpy off road terrain?
BlueBronco
DFW
Improvements needed:
-wider at top and rear so soft top and can be stowed and rear gate opened
-mounts or braces to rear frame to for better support on side loads
-black paint to hide the ugly
Below is my soft top roof rack. However, it is kayaks and light loads only, I wouldn't attempt a roof top tent with the current design.
Ford Bronco . 1688583565343
Ford Bronco . 1688583465339
Ford Bronco . 1688583487011
Black_Stallion13
Cincinnati
Tacoma
Paint it matte black and it will look 1000 times better. That being said, I’d take the literal 2 mins to setup my pop-up tent or just sleep in the back vs. mess with any rooftop tent. The cons waaaaay outweigh the pros to me but that’s just my .02
