- Austin
- Sep 27, 2020
- 46
- 996
- 1,567
- Houston, Texas
- 2019 Subaru Crosstrek
- Base
Thank you for your help. Unfortunately much of what I'll do will be on sand so I have some decisions to be made.My word is as good as gold.
$$$. Most people wouldn't actually use a locker or a limited slip. If automakers can repurpose the ABS and traction control modules that they already have to put in the car to give you some fraction of the capability at basically zero cost, they'll do that first.
The issue is that it's a reactive system. A wheel has to slip first, then the system pulses the brakes, then it transfers some small amount of power momentarily, then repeats until you're either unstuck or hopelessly stuck.
In conditions like loose dirt and sand where momentum is important, a locker or LSD is the best way to maintain momentum. WIth an open diff, one wheel has to start slipping, which means one wheel is digging instead of pushing you forward.
Yes, without 4A, it's in 2wd until you manually switch to 4. It's how most trucks have worked for most of history. Only in the last decade or two have they started putting automatic 4x4 into trucks. Jeep has had a few variations on automatic 4x4 over the years ("Selec-Trac," "Quadra-Trac," etc.).
