Anyone level a Sasquatch Bronco?
Ksjrb03
Tx
F250
Leveling out the ugly Ford rake is not nit-picking. It’s the first thing I do to every Ford truck I buy, and now SUV.
Gamecock
Leveling the sasquatch puts the CV into a position that will cause it to bind at full droop. Just don't go off roading with it and you should be fine (not sure if you're making a mall crawler or a real offroader - not judging, everyone has a different reason to buy it). If you're planning on doing offroading then you're better off using a full coilover upgrade.
https://www.bronco6g.com/forum/thre...ide-lift-heights-with-wheel-tire-sizes.17719/
It won’t if you do it by adding a bit taller springs to the existing coil over…but someone needs to build them.
BroncoZ13
Georgetown, TX
2021 Bronco Badlands 4 Door
The Wheels and Tires are 17x9 Dirty Life Canyon Gray Wheels 35" Nitto AT Tires 6x5.5 2021 Ford Bronco off Ebay seller: auto-addicts
(I specified12.50X35R17) the ones they advertise have 315/70R17 the wheels are 0 offset 5" backspace they sent them with the Tire pressure sensors, that were already programmed for my Bronco, I literally Bolted them on Torqued to 100 ft. lbs. and done they were truck shipped on a pallet that was carefully set up and shrink wrapped including 27-splinned lug nuts and socket to mount all wheels including the spare I got them in 3 Days after order Date Very Satisfied with the entire experience as far as the 1-1/2" level kit I had it installed at 4wheelparts.com ($638.45)including a 4 wheel alignment and on a level surface it is dead-on level! and the shackles (D-rings) are from Harbor Freight and the say Badland on them APEX 3/4 in. D-Ring Shackle (harborfreight.com) I painted them orange to match also I bought: 10,000 lb. Capacity 3 in. x 30 ft. Recovery Snatch Strap (harborfreight.com) and a: Receiver Tow Hook (harborfreight.com) as well.
That stance looks perfect. It’s interesting that 4WP did the install. I went to local shop in Austin, TX and they said there isn’t currently a kit for the SAS that 4WP had approved to install? Ford dealer quoted me $500 to have the 1” Zone installed, so considering that.
my Badlands 4 Dr SAS def has a 1-1.5”rake, so I want to install but so many have stated concern for bad angles and actual off road use.
either way, you have a great looking Bronco!!
Ford Bronco Anyone level a Sasquatch Bronco? 72E84027-D120-4EA9-A44D-391F530E39F8
Ford Bronco Anyone level a Sasquatch Bronco? F21E29E8-F4CF-43AF-97B2-478D10C3B58E
Ford Bronco Anyone level a Sasquatch Bronco? 94ADC46A-4FE1-48B3-8D39-2BFE512F20B4
Perfect-Beast-2
Rick
Virginia and NJ
1973 F100 / 1980 F150 Stepside / 2019 F150 Lariat
I’m adding 35” tires to my non sas BD as soon as the wheels ship. I already installed the lift (1” front, 2” rear). What is going to be the problem exactly?
bodean
Shawn
Alberta, Canada
76 Mini, 99 4Runner, 07 FJ Cruiser, 16 Tacoma
You do you, but I’ve never understood level kits. The only time is sits level is when it’s parked. If your accelerating, braking, any load in the back…not level.
Couple months later, throw a winch on…not level.
airishfan
rob
North Las Vegas
jeep cherokee
I dont like the rake on the Bronco or any lifted vehicle but I am worried leveling it well make it harder to see when off-roading .
Nolabel
Van
Mesa Az
Has anyone leveled a squatched Bronco? Not lifted front and rear, just added a small spacer or made another adjustment to get the front up to level. Mine is about 1" low in the front and I personally don't like the raked look. The whole point of going sasquatch was to have a trail ready rig that I could use and abuse until upgrading the coilovers to Kings in the future but I'd love it leveled out sooner than later. I know it is nit-picking but it's the only thing I can complain about my Bronco.
To be completely honest I think leveling a vehicle is useless unless you only plan on mall crawling it for the look.
I plan on adding gear on my trips which will sag the rear suspension and level it out. Most of the time I have something in the back like gear or kids and have never needed it. My friends Tundra is leveled and it almost feels like your leaning back and makes it harder to see out the front unless you raise your seat more.
To each their own I guess.
Clearwater native
Tom
19F-59,16-E350, 65C10,05TJ, 67RSCamaro, 65malibuSS
Exactly to each their own,
I am very happy with my Bronco and hopefully you are all happy with yours level or not.
I plan on installing new axles as soon as they are available anyway and in the next couple of years better suspension products will be available also
Spicer Extreme™ Half Shafts | Spicer Parts
Clearwater native
Tom
Thank-you for the complement! here is the link on the 4wp website for the kit: 2021 Ford Bronco| Fabtech 1.5" Leveling Kit - FTL5212 | 4wheelparts.com
pakrat
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
Well thats kinda the question isn't it. How do you get an inch or so in front without using a spacer lift. Can the sasquatch be adjusted at the coilover?
Most other offroad vehicles I have owned I felt the need for upgraded suspension whether it was a jeep, 4runner, or Tundra or others I generally upgrade the suspension on purchase new or used. More travel fit larger tires etc. Rear shocks, springs, or leafs. In the front upgraded and adjustable coilovers etc. Those upgrades allow for leveling the front end a little while improving suspension performance.
With the Bronco I'm pretty happy with the performance so far. No need for upgrades when it comes geared properly and has larger tires with decent suspension. It will obviously be easy to achieve leveling when I upgrade in two or three years when things inevitably start leaking or are damaged. Until then I might have to live with it.
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
I'm not hating asking a real question why upgrade? Have you broke it to need upgrading or just want it?
In my years of having 4x4s never seen or broke an axle that wasn't drivers fault.
Are they longer or just stronger? Looked to just be stronger.
Do they allow for more lift because they allow for more angle.
I read all I see was stronger.
Again I'm not hating if its just stronger but do you get more?
Clearwater native
Tom
Again I'm not hating if it's just stronger, but do you get more?
I see a weakness in the stock axles and as always, I am looking for stronger/better suspension parts, I will aways be ready to upgrade anything to make my Bronco Better and more reliable that is just how I roll.
Hoghank
Hank
Ca. 95228
Corvette, bronco sport, gmc,mustang,Cadillac,porsc
What kit did you use? I’ve been looking for a badlands non sas lift kit.only found zone 1” front leveling kit.
