EDIT (fixed) Anyone notice poor hood alignment?
Mustang Mike
Toronto Ontario
Mustang GT
I’ve alredy addressed the issues with my service department but thought I’d ask to see if anyone has noticed crazy bad gaps in the hood/fender area?
You can really see it on the pictures below there’s an almost 1/4” “dip” in the middle of the hood on the passenger side where it meets the fender. Also from head on there’s a gap big enough to fit my index finger (again passenger side) between the grill and hood. It’s like a 1/8” on the driver side?
EDIT: Hood replaced under Ford warranty!
The hood was actually here a couple months back but I (along with the shop) was dragging my feet on painting and installing it in hopes of avoiding the salt/sand on the roads right now.
Overall I’m very happy with the results, both fit and finish (pint match). It helps that my dealership happens to use the same shop I do, so I personally know the guys who work there and they’re very good at what they do!
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? 1D347B07-564D-449C-8510-B84F59E45491
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? A383FBA0-90B6-4C33-830A-942981F9C41F
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? 53478715-2FC3-486A-9E44-871FA550BBBF
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? 3350247C-C420-4F26-9E22-ED3C7664CE03
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? A52AB78B-96B2-4938-BE61-59EF313887D8
Pre-Replacement Pics:
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? B4A14A46-9B04-45D4-9216-FCD653054A19
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? A516E86B-BBCF-45E3-A94F-F4661B8216FD
Ford Bronco EDIT (fixed) Anyone notice poor hood alignment? 1886C5D8-D4E9-41C6-8A39-81B6850A45FE
BroncocnorB
Paul
1965 Cobra,
I don’t think that’s acceptable. You need to get with dealer to have body shop make it right. SMH
AceGoliath
Charles
IL
21 Bronco OBX SAS , 22 Maverick XLT, 10 Fusion SE
Your hood almost looks dented in/concaved on the passenger side. Mine sits lower on the passenger side vs the driver side too, but it is not as bad nor is there a dip in the center like yours. It is even for the length of the hood.
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
Yeah, that’s not supposed to be like that. Mine doesn’t have that dent.
AlpineDescent
Allen
Michigan, USA
Escape, Mustang
Thet is a bend, not an alignment issue. That is probably why it sits high on the passenger side at the front. Dealer should fix or replace it.
JohnnyBronco
Pennsylania
X4
My hood sits slightly lower than fender top edge of both sides equally. Visible from drivers seat but others on here have said ot is normal
slohatch
Daniel
Challenger redeye
Under the hood there are 2 black rubber pads on threads you can twist them up or down. They are near the corners by grille
Mustang Mike
Mustang Mike
Toronto Ontario
Mustang GT
We'll see what the body shop says.
At the end of the day I'm happy to have my bronco and at least I can enjoy my truck while awaiting a fix!
Rosalieee
R
LA, CA
Raptor, BMW M3 Competition X-Drive
I have a very very similar issue. Same spot but on the drivers side.
I decided to forgo having the dealership do anything - figured their body shop would make it worse (alum hood) or a replacement and repaint would not match
Mustang Mike
Mustang Mike
Toronto Ontario
Mustang GT
Ford is going to replace the hood, no ETA yet as I just got word a “warped” hood is well within the warranty!
Desert_6G
Phoenix, AZ
Ranger
wow your lucky. I figured Ford would say the tolerances are within spec. I had gaps much worse than that on my Ranger and they wouldn't fix it.
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
I must have missed the news. Did you finally get yours?
Oh yea Bronco!
Amber
Ferndale, MI
10/21/214dr BB, 2.7, A51. & ‘90 Wrangler V6 MT 4.2
After reading the entire thread I see the dent/warping now. I’ve noticed misalignment with mine too, but haven’t noticed anything like your dent/warp. I will be attempting to adjust using the 2 rubber things like slohatch mentioned. Thanks for posting!
