Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
I finally got around to installing the KR Air Coupler Switch Bracket and ARB Pressure Control Kit. I went overboard ordering hoses and couplers from @4x4TruckLEDs.com, but in the end only needed what is listed below to achieve a clean install.
Parts List:
ARB On-Board Twin Air Compressor
KR Off-Road ARB Compressor Engine Bay Mount
KR Off-Road ARB Compressor & Air Coupler Switch Bracket
ARB Air Hose Coupler (JIC-04 37 Degree Flare Fitting)
ARB Air Hose Coupler Dust Cap
ARB Reinforced Hose JIC-04 0.5m
ARB Reinforced Hose JIC-04 0.3m
ARB Adapter 1/8 BSP (M) JIC-04 (M), 2 Pack
ARB Adapter 1/4 NPT(M) JIC-04(M), 2 Pack - Only 1 required
ARB Air Line Adapter Fitting 45 Elbow, 2 Pack - Only 1 required
Please note, due to the configuration of the ports on the ARB regulator I was unable to have the input and output hoses on the same side, so the layout is a bit more spread out than I would have preferred. Also, the spot where I mounted the regulator needed to be twisted a bit so the pressure sensor would clear the coupler. Finally, the screw I used for the regulator mount was a bit too long, so I used four washers to take up the extra space.
Initially I planned on using the supplied ARB switch, but I decided to forgo that idea because using the upfitter switches made for a cleaner install.
Hi Aman!
Why did you install a Pressure Control Kit?
I just got around to installing my ARB Twins, and wired it to an aux switch.
MrGreen55
Kyle
Oregon
toyota scion xb
Hi Aman!
You can set the PsI that you wont to for airing up / airing down with your phone.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I connected both the air compressor's trigger wire and the pressure kit's power lead to switch 6. More than enough amperage to handle both.
Now I want to install one of these :)
*looks at the ARB stuff on shelf*
I mean... I've GOT the supplies necessary :)
Cat
Cat
Whidbey Island, WA
BroncoKong Jr.
Andrew
I've been curious about the pressure control for a while now. Cool to see it installed! Let us know how you like it. (y)
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Bronco Bob
Bay Area Ca
1977 Bronco, 1994 Bronco, 2009 F150, 2017 F 250
So You can set it with Your phone and just walk away and it will cut off at the desired setpoint?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Can you put together a list of the parts you actually used? Or was that the actual list of what you DID use on the first page? I know you ordered a LOT of parts from us, not sure what you used or if that was just a list of everything purchased.
I've had some folks email me asking what the parts list is.
Potluck99
Las Vegas
1969 CJ5, 1977 J10, 2022 Lowrider ST
I got a refund as soon as they received my returned item ¯\_(ツ)_/¯
Look at the history with this guy. Suprised he still posts on here. There’s whole threads about him.
Panzer948
Charlotte, NC
1981 CJ5, 2015 BMW M4, 2019 Jeep G.C. Trailhawk
Parts List:
Ford Bronco ARB Twin Air Compressor and Pressure Control Kit Install E7EAF22A-4EF6-4C5F-8B9B-68D4EFB55876
Excellent work! 4x4TruckLEDs has finally shipped my dual compressor and bracket (I had already received the Air Coupler Switch Bracket). I should get them by mid week and do the install over the weekend. Good timing for your post! I am still on the fence about using the supplied switch (and mount it near the coupler) or the upfitter switches. I will play around with it when I get the parts. I may post pics when done.
Aman
Aman
Aman
Northern NJ
Thank you!
If I had not purchased the Pressure Control Kit, I would have used the supplied switch mounted on the Air Coupler Switch Bracket. However, since the PC Kit gives me Bluetooth control over the compressor, I decided to use the upfitter switches.
ICUGAZN
Kevin
2019 Raptor
Did you do this install yet? I'm interested if there is anything I would have to do if my compressor power is wired to an Aux switch already.
