Benzo520
Ruben
Tucson, AZ
Are you rubbing at all on the new UCAs? I just recently did a 1.5" pucker lift front and rear, added 37" tires and I'm slightly rubbing on the UCA at full turn. But I'm also on stock squatch wheels
rguest3
Raymond
Florida and Virginia
F-350, F-450, 2022 Bronco, (2) 77 Broncos
Just curious??? With the 0 offset wheels, how much room is there between the Camburg UCAs and the Inside of the Tire?
Thanks
M Redwood
M
Prescott az
2022 BB,BASE
Nicely done ...I've decided that 4 doors look best on 37s and 2 doors on 35s...for my taste.. so your basically 4 inches over non sas models on front so how is the front cv angle looking? Pic?
BAUS67
redneck
Central PA
Looks great! I love how people who have probably never been rock crawling like to tell those who do, what works and what doesn't...
Yeah, last time I checked taller tires gave you added ground clearance. Added ground clearance a good thing for rock crawling. :unsure: But I guess I'm the bad guy.:cautious:
Bdockins
Ben
Ga
1990 F150
That side stripe graphic… fantastic.
Details ?? 🙂
broncoepic
Bronco Badlands Sasquatch
Nicely done! This thing will kill it out on the CO trails! I feel 37s are the sweet spot for the Bronco. Install the BroncBushing and the full tie rod kit to strengthen the steering system. It’s going to be an awesome 2022 wheeling season with our Broncos.
Last Ride Bronco
southern USA
Nissan pup
Couldn’t help but notice the April 1 date on the temporary tag. Good way to remember the deadline.
Ford Bronco Area 51 Badlands Sasquatch with 37s, Lift, Camburg UCAs, Adjustable Rear Trackbar 00E39B7B-A48F-4176-9D5F-5B8752319262
tritonx100
2020 ford explore
Added a few things in my cold garage:
- 3" front / 2" rear spacer kit
- Camburg UCAs
- 4WP Adjustable Rear Trackbar
- BFG KM3 37" Tires
- KMC Wheels
Everything feels super smooth and the tires are quite. I feel ridiculously high up but it's a great feeling. The ride is slightly stiffer with the spacers compressing the springs more, but unnoticeable when I air down. I have to trim a little bit from the inner fender well by the pinch points but I'm used to doing that with all my Toyota's.
where did you get the side decals?
ramblinwreck
Georgia
`22 Wildtrak, '21 Wrangler Rubicon 4xe
If it’s anything like Jeeps, your perception of too much tire will change over time. 10 years ago 33s on a Jeep was oversized. Now everyone runs 37s lol.
I do like my 35s just fine on my Bronco though, and have no plans to go larger. This one looks good to me though.
Gtrekker
Gary
Nicely done!!!👍👍
MUDLVR
MUDLVR
Justin
Colorado Springs
2022 Badlands Sasquatch
I was rubbing slightly on the rock rail. So I whipped out the angle grinder and chopped the bit off
MUDLVR
MUDLVR
Justin
Colorado Springs
Thanks
Ford Bronco Area 51 Badlands Sasquatch with 37s, Lift, Camburg UCAs, Adjustable Rear Trackbar 20220224_155649
MUDLVR
MUDLVR
Justin
Colorado Springs
The CV axle is perfectly proportional
Ford Bronco Area 51 Badlands Sasquatch with 37s, Lift, Camburg UCAs, Adjustable Rear Trackbar 20220224_155634
Ford Bronco Area 51 Badlands Sasquatch with 37s, Lift, Camburg UCAs, Adjustable Rear Trackbar 20220224_155621
