Auto Start Stop Delete?
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I don't think removing ASS results in a less HD starter and Battery. The $50 credit is because they don't have to install a chip, doubt they would use a different starter and battery as that would be a lot to track. That being said, here are your options:
ASS Plug: As mentioned above, these are aftermarket devices that you can plug in to disable ASS
ASS Wipe: Removing the ASS enable from the software with Forscan
ASS Hole: When you remove a hood or other sensor that disables ASS, leaving a hole where it used to be
ASS Tow: Tricking the Bronco into thinking a trailer is attached, I don't recommend this because the one time I hauled a trailer, it new a trailer was hooked up and changed many settings, and I think shift points. I was getting 14mpgs hauling an empty uhaul utility trailer :(
However you wish to address your ASS, just make sure you do so in a responsible manner because the government is all over your ASS. Additionally, if you take your vehicle in to the dealer and the service advisor notices some mods, they might probe your ASS without lubricant (dry start/stops are not good) concerning warranty!
BigHoof
PA
Ram 2500
There's a new ASS eliminator that came out on Amazon that's $50. You don't have to take anything apart and it installs under 5 minutes above the kick panel on the driver side.
These work different than the forscan "fix" I believe. These plug-in eliminators, basically re-push the off button on the startup.
The Forscan tricks the Bronco and to going into Start stop mode by thinking that you are providing input (I think it's turning the steering wheel).
I tried the one on Amazon but sent it back. First issue, it did not work with a manual transmission. Second issue is that the wiring is not as heavy as stock. The positive and negative wires in port #1 and #2 are much heavier than this one so wouldn't use it on any Bronco.
da_jokker
Jeep Wrangler JKUR
I've had it for weeks And it's been working great, of course I have an automatic so I don't know if that makes a difference.
Also, the wires don't need to be as thick because they're not as long. How many amps do you think are going through that?
I'd be curious what gauge of wire the established auto start/stop eliminators use.
Deb68nc
Debra
Raleigh NC
Toyota Tacoma
I’ve had mine for two months so far working every time. I haven’t read anywhere where it stops working so hopefully it won’t be a problem for us
Ziemann
Northern Wisconsin
'23 Ford Bronco 2-Door 2.3 MT
Explain why it doesn't work on a manual?
BigHoof
PA
Ram 2500
That's not how wiring works. You should never take a 10' run of wire that is 12 gauge and insert a short piece of 18 gauge in the middle. #13 and #14 are also 12 gauge from the factory so that is 4 total in that connector. No wire on the cheap Chinese harness is anywhere close to 12 gauge. The rest of the OEM are 22 with one that is 20.
The original ASS is in a totally different area and doesn't have the same wire size issue.
da_jokker
Jeep Wrangler JKUR
Yup, there are 4 options.... In order of cheapest to most expensive...
1) get in the habit of pushing the button with your finger whenever you start the vehicle.
2) buy a $34 adapter and use Forscan to trick the bronco (But the button won't reflect what's actually going on)
3) buy the $50 Amazon solution that is a "new" design.
4) buy the $100+ established auto start eliminator It has been around for years.
CaptFett
Drew
NoVa
Lx470
Sitting on the can reading this. Cannot stop laughing!!!
Cactusjk
Woodland Hills, CA
2023 BL 2 Door, 2007 FJC
I guess I am missing where the Amazon one connects to. I do not see anything visible by the drivers kick panel? If anyone has install pictures that would be greatly appreciated.
da_jokker
Jeep Wrangler JKUR
Look right above your driver kick panel. There's a black box. It is that cream colored plug
Ford Bronco Auto Start Stop Delete? 20230515_061653
Cactusjk
Woodland Hills, CA
Thanks! See it now. Now as long as it works with a Badlands!
Cactusjk
Woodland Hills, CA
See pics above.
Installs on the corresponding wire harness on driver’s side kick panel. There are 2 identical plugs - use the one toward the rear of the vehicle.
So the Amazon works on your Badlands?
Bschurr
NY
Works on all models. I bought one for my buddy who has a 2022 Outer Banks and it worked for him too. The electronics for this connection point are identical regardless of trim level
