Im certainly pretty nervous after already having it leak and not even a week into ownership. Leaks tend to get worse over time…Not acceptable.
Yes, mine looks the same. I thought something wasn’t right but I looked at a couple others and they looked like mine alsoDoes anyone else’s top have a section in the front window by the back where it looks like it’s essentially missing a chunk of the outside rubber? Both sides.
I'm pretty sure I noticed something similar on my MIC 1.0 the other day. I will double check when I get home this evening.Does anyone else’s top have a section in the front window by the back where it looks like it’s essentially missing a chunk of the outside rubber? Both sides.
Yes mine has this. I believe this is the water run off point between the front and mid panels.Does anyone else’s top have a section in the front window by the back where it looks like it’s essentially missing a chunk of the outside rubber? Both sides.
Mine have the same. I pointed this out upon delivery of both but do believe this is a drainage related area.Yes mine has this. I believe this is the water run off point between the front and mid panels.
(Ford is aware and in communication, so we don't need to keep pinging them)
Updated photo from this AM. My hands aren't Samsquatch in real life, that's just the zoom level. You can see the fuzzy look on the edge, and that wasn't there when I picked it up 5 days ago. You REALLY have to be looking for it though.
Bad news, folks. This is a MIC 2.0 top built 10/1, delivered 4 days ago.
Top looked excellent at pickup. Did not notice any issues.. 4 days later, I notice I can see the old issue returning. Have not notified Ford yet.
Check your MIC tops CLOSELY on the rearmost panel by the windows. Appears to be pulling apart a bit.
I'll have a lot more photos and any other misc info coming shortly.
There is also slight honeycombing.
Edited for brevity.
Updated with some photos posted later in thread by @AJ_West_
Apparantly you haven't seen the quality of the Jeep Wrangler tops. There is absolutely no reason the hard top on the Bronco couldn't be the same. To automatically expect bad quality, and then accept it does nothing to improve the problem.i think you guys have unrealistic expectations about how these things should look for the most part. if these are cast parts, they will come out with slight imperfections. to expect otherwise is a little foolish. I'll gladly trade you one of these for my soft top plus cash
That is certainly what Ford is hoping for from its Bronco owners! That’s just the way it is, nothing Ford can do about it, so we’ll just have to live with it! Why does Jeep not have the same fit and finish issues with their hardtops?i think you guys have unrealistic expectations about how these things should look for the most part. if these are cast parts, they will come out with slight imperfections. to expect otherwise is a little foolish. I'll gladly trade you one of these for my soft top plus cash
yes, we all with MIC have that. These are cabin pressure vents, at least that is how I interpret them.Does anyone else’s top have a section in the front window by the back where it looks like it’s essentially missing a chunk of the outside rubber? Both sides.
