Badlands on 33's tire pressure on pavement poll
What Tire Pressure is everyone running on the street with the 33in Ko2 Badlands?
  • Total voters
    53
Blksn955.o
Greg
Wentzville, MO
Picked up my Bronco and like others have mentioned my tires were at 42psi. When I got it home I dropped it to 36psi and it rides better on the street.
Looking to see what everyone else has experienced? Has anyone done the chalk test?
old goat
Raul
Collin Co. Texas
Chevy Colorado
has anyone looked at the spec tag on the inside door panel ???????
use that number
I alway do and have no question about what to PSI it.
BroncocnorB
Paul
1965 Cobra,
Yeah cars typically ship with higher PSI to mitigate flat spotting
Blksn955.o
Greg
Wentzville, MO
I get the higher psi for shipping, strap the wheels and let the suspension do its job.
I have often found the door psi to be a guide at best depending on what I am doing. Around 32-35psi I have found to be my basic sweet spot for comfort, mileage, and wear. Just wondering if others have found a sweet spot.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
32 to 35 psi was what I previously ran in my cars/suv for street driving. On my Badlands with the 33s, 32 to 35 psi felt kind low for everyday driving.
When doing a bit of offroading I noticed how soft and very flexible the tires were already at 31psi. At 30ish psi the pressure warning came on. This is why I feel 32 to 35 is a bit low for pavement, especially if loaded up with cargo.
I've been driving around at 41 psi for normal use. Both times I wheeled the trail I mentioned above I drove there and back at 31psi. 30 min round trip. 31 vs 41 psi had almost no difference to me on the road. But I wasn't paying close attention.
The other reason I keep it up above 40 is that I've noticed these larger tires are more susceptible to temp changes and I can be down as much as 5 or 6 psi on a frozen morning. Only during a warmer afternoon driving on dry pavement will the pressure raise back up near 41psi.
But each person has their preferences. My coworker has some Toyo A/Ts on his F-250 and leaves them at 60 psi because sometimes he has a heavy load.
I'll admit I never checked the door sticker yet. What's the 4door badlands say?
Jalgieri
Audi A4
Be sure to do the chalk test on hot tires then let them cool and measure the pressure on each tire so you know how to get the best ground patch for each tire.
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
On my old FSB I ran the 35x12.5R17 tires at 32psi for road use, that truck scaled at 5500# with standard gear onboard. My Raptor ran the 315/70R17 at the same weight as my Bronco but the factory spec was 38psi, the recommended pressure from the forum for all around comfort and MPG was 36psi.
On my 2 door badlands the factory sticker shows 39psi, which I believe is too high for a 4705# truck. I’ll try 36 and see how it does. It currently has 13 miles on it, so I haven’t driven it much since delivery on Tuesday (it doesn’t have plates yet).
Ford Bronco Badlands on 33's tire pressure on pavement poll 34D8A95D-BBFC-4012-856F-69BBC9A8B432
Black_Stallion13
Cincinnati
Tacoma
Does anybody have the actual door sticker psi for a 4 door badlands with 33s??
BroncoAZ
Mitch
I’ve been running mine at 34 psi with 285/75R17 C load rated Toyos.
