- Joined
- Feb 21, 2020
- Threads
- 111
- Messages
- 7,264
- Reaction score
- 25,477
- Location
- North Texas
- Vehicle(s)
- SUV
- Your Bronco Model
- Undecided
- Thread starter
- #1
UPDATE: 6-14-2021: We now have full insight to the differences in lift height between all trim levels in this new thread:
The Definitive Guide to Bronco Ride & Lift Heights with Wheel & Tire Sizes
The purpose of this thread is to try and collect enough information to finally determine the height differences between all the trims. Numerous threads and posts have discussed this but have not arrived at the true differences that not even Ford will tell us. The only way we can make a final determination is to look at real hardware. This effort may not be finalized until we see the final sales units as the pre-production demo models may still have some early development parts on them.
So far these two graphics summarize the findings to date:
The first set of part numbers are from @618TRVLWILD
Bilstein P/N: F4-BE5-M970-W6
Ford P/N: MB3C-18080-ARJ
TBD P/N: 202660079
The second set of part numbers are from @Pittguy, not the differences from above:
Bilstein P/N: F4-BE5-M968-W7
Ford P/N: MB3C-18045-ARH
TBD P/N: 203500325
@mtap photos:
TBD P/N: KB3ASY 00034
TBD P/N: 210126A
The Bilstein "F4-BE5" part number denotes the Bilstein 5100, non-reservoir, family of shocks. However since this is a Badlands, which include units with an external reservoir we have to assume Bilstein is playing with the part numbers for Ford or these are Pre-Production units that do not have the final part numbers assigned. The second part number is Ford's per @Scumby. The third part number did not reveal any information in a Google search.
So we can see the standard B-OB shocks share the same Ford base number as the BL, WT, FE and Sasquatch, however, those have have the added -ARJ or -ARH to denote the reservoir body shocks. Also of note are the two reservoir body shocks differ in the middle part number from -18080 to -18045
The "HOSS System with Bilsteinā¢ Position Sensitive Dampers" appear to be a derivative of the Bilstein "B8 8112" family which are called the ZoneControlĀ® CR family. These dampers-shocks are that are available on the BL, WT, FE or Sasquatch package.
BILSTEIN B8 8112 (ZoneControlĀ® CR) Damping perfected
The standard "HOSS (High-Performance Off-Road Stability Suspension) System" are on the B, BB, BD and OB. Currently these have been seen as black colored shocks so what Bilstein series these are is still unknown.
REQUEST: For anyone that is able to see the Bronco's in person, please see if you can get photos of the dampers-shocks with the part number sticker and then post them with the model they came from.
"HOSS System with Bilsteinā¢ Position Sensitive Dampers", photo thanks to @618TRVLWILD and @Pittguy
Standard "HOSS (High-Performance Off-Road Stability Suspension) System" are on the B, BB, BD and OB, photo thanks to @mtap
HOSS System with Bilsteinā¢ Dampers - Shocks by Trim level
Thank you to @618TRVLWILD Ashley for getting photos at a demo yesterday and to @Pittguy for photos from an event he attended.
: STL Ball Park Village Event: (2) Badlands 4-Door Broncos in Race Red & Rapid Red
For further analysis please see the great thread by @Werkedperformance here:
BILSTEIN ESCV Bronco suspension / shocks explained - "End Stop Control Valve" Dampers (Bronco HOSS Suspension w/ Position Sensitive Dampers)
TBD P/N: 202660079
TBD P/N: 203500325
@mtap photos:
TBD P/N: 210126A
