Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Interesting catch, so I wonder if the spring seat part is different or if that is adjustable?
North7
North7
North Texas
SUV
@North7 would you be able to do the old B/BB/BD/OBX vs non-Squatch ride height measurement for us? The more basic trim people still "need" that info.
That has been debated a 1,000 times with dozens of bits of information, the answer is:
No one has figured it out yet.
Maybe with everyones observations in this thread we will finally get the answers.
5280Bronco
Denver
As far as i have seen, the "base" trims have black generic shocks. Probably not bilsteins. While BL and squach have the bilsteins. It will be interesting to get more info. That spring perch location is definitely different and it would make sense.
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
Zack beat me to it. was typing up the same thing. The reservoir is just flipped upside down on it's mount is the "2 inch" difference between the two.
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
I am curious to know which one will be on the BL I ordered.
This is a photo that AutoBlog posted almost a year ago
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences Pittguy 3
Dads_bronze_bronco
Wonder if the answer to the difference is snap rings (would be a low cost way for Ford to change between Squatch and Badlands):
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences FC54C26B-A216-49E2-8642-11F0671CDA12
Marauder
Josh
St Louis
Thank you to @618TRVLWILD Ashley for get a photo of one of the two Bilstein shocks at a demo yesterday, as shown in this thread:
šŸ“ø: STL Ball Park Village Event: (2) Badlands 4-Door Broncos in Race Red & Rapid Red
Taking the Bilstein part numbers from the photos here is what I found so far:
F4-BE5-M970-W6
MB3C-18080-ARJ
202660079
The Bilstein "F4-BE5" part number denotes the Bilstein 5100, non-reservoir, family of shocks. It is not the upgraded "HOSS System with Bilsteinā„¢ Position Sensitive Dampers" that are standard on the BL, WT, FE or Sasquatch package. It may be safe to assume these are the the "HOSS (High-Performance Off-Road Stability Suspension) System" standard on the B, BB, BD and OB.
What we can see from this Demo Badlands is that some of the demos are built from frankenstein parts as all Badlands are supposed to have the upgraded Bilstein Position Sensitive Dampers with the external reservoir.
REQUEST: For anyone that is able to see the Bronco's in person, please see if you can get photos of the dampers-shocks with the part number sticker and then post them with the model they came from.
The "HOSS System with Bilsteinā„¢ Position Sensitive Dampers" appear to be a derivative of the Bilstein "B8 8112" family which are called the ZoneControlĀ® CR family.
BILSTEIN B8 8112 (ZoneControlĀ® CR) Damping perfected
Standard "HOSS (High-Performance Off-Road Stability Suspension) System" standard on the B, BB, BD and OB.
Upgraded "HOSS System with Bilsteinā„¢ Position Sensitive Dampers" that are standard on the BL, WT, FE or Sasquatch package.
HOSS System with Bilsteinā„¢ Dampers - Shocks by Trim level
Ford Bronco {thread} {filename}
For further analysis please see the great thread by @Werkedperformance here:
BILSTEIN ESCV Bronco suspension / shocks explained - "End Stop Control Valve" Dampers (Bronco HOSS Suspension w/ Position Sensitive Dampers)
Outstanding analysis. Thank you!
Thed
Ben
Raleigh, NC
If it really is that simple then I know exactly what my first mod is going to be, a free lift on the front end.
