North7
North7
North Texas
SUV
I wonder if you cut a cross section out of those Bilsteins, you'll find a Fetzer valve, ball bearings, gauze pads, 3-in-1 oil, and 'bout 10 quarts of Prestone anti-freeze........no; make that Quaker State.!?
Hard to tell, they cleaned this one up before they took photos.
Thank you to @Richw23 for this diagram from this post.
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences 190b90a1-9445-4e0e-8c2b-497827776088-png
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
Are you talking about these two?
Because to me it just looks like the reservoir is oriented in opposite directions:
Great catch. Engineering tests for reservoir location.
Erock
US
2018 F150 Alpine edition
Almost looks like a snap ring on the spring perch... but it also looks like a render to me, so maybe I’m just seeing things. However, if it’s not welded on, the perches would be pretty easy to modify/make.
Regardless, thanks for a thread with an actual attempt at information... instead of the “normal” stuff of late.
North7
North7
North Texas
SUV
Your simply looking at the left and right versions in the individual photos, the reservoirs are inboard on both, as seen in this chassis photo.
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences Bronco Shocks
North7
North7
North Texas
SUV
Here is another photo of the cutaway.
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences scv-2021-ford-bronco-suspension-shocks-dampers-png
mdonathan56
If you look at the location of bottom of the reservoir to the bottom of the shock, it looks like reservoirs are flipped longitudely.
North7
North7
North Texas
SUV
Great observation, now I see it, looking at the weld points on the reserviors.
mdonathan56
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
Wonder if the answer to the difference is snap rings (would be a low cost way for Ford to change between Squatch and Badlands):
Another guy and I were discussing this a bit ago. If that's all it is for the height change, it will be amazing.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Hats off to @ZackDanger. Keen eye again.
I DONT KNOW WHY I NOTICE ALL THESE THINGS ALL THE TIME IT JUST KIND OF COMES NATURALLY TO ME FOR SOME REASON YOU GUYS DONT FEEL THIS WAY THATS WEIRD I WONDER WHY
Ford Bronco Bilstein HOSS & Position Sensitive Dampers Part Numbers & Differences 1617919238457
5280Bronco
Denver
I'm just convinced you don't work at all and just refresh the forum main page and reply as soon as you see any updates all day long. Or you "watch" every post and do it that way. You're a machine.
North7
North7
North Texas
SUV
It's a gift you have Zack, I was in a training class once that discussed something similar. They explained that a very small percent of people, I believe it was less than 20%, have the ability to perceive small, minute differences in things, count your blessings.
Erock
US
@North7 still looks CGI to me... no threads apparent on anything, especially the inner rod, at either end. I’ve been wrong before though.
