Farmerjack
Billy
Arkansas
farmerjack.com
2017 f250
First off I want to thank @flip for the hitch and trailer brake controller.
Parts I purchased for this install.
1- Bronco Raptor hitch
2- captured 3/8 nuts
1- Borla muffler 2.5 offset/center
1- 3” stainless j bend pipe
I haven’t seen any info on this yet, and I thought I would share. Short story is I removed factory hitch, removed rear muffler. Then I installed Borla muffler midship and built new tailpipe. Also built temporary kicker bars until oem braces become available. The factory crossmember has spots for captured nutrecommend m10’s but I only had one in the tool box so I used 3/8 nuts until I change the braces out. Sorry in advance for terrible pics. Lol
I hope this helps anyone that is thinking about doing this.
Ford Bronco Bronco Raptor hitch DIY install with pictures DF1BFDF7-1DB9-49B4-9498-042B6AB2E510
Ford Bronco Bronco Raptor hitch DIY install with pictures 3BB26543-E8D0-4162-BD10-5AAD3FBFCFD4
Ford Bronco Bronco Raptor hitch DIY install with pictures F34763D8-B908-42DA-851E-3CDDE097BCA7
Ford Bronco Bronco Raptor hitch DIY install with pictures 7B91CA03-ACDC-4CB5-AFC3-8AFA2A66C7E3
Ford Bronco Bronco Raptor hitch DIY install with pictures D1FAE9F4-72B3-4EEE-9B8B-67D863B476B6
Ford Bronco Bronco Raptor hitch DIY install with pictures 2A4DB94E-C7A3-4843-8FC0-F5ADAF0D27E6
Ford Bronco Bronco Raptor hitch DIY install with pictures A20861A7-DF0A-4420-A7CB-7D1874FD6C30
Ford Bronco Bronco Raptor hitch DIY install with pictures BE56E6C4-F180-4CA1-959E-025E32A293C1
Ford Bronco Bronco Raptor hitch DIY install with pictures 534BE45F-071E-4DA1-9C4A-BE3A0D54E220
Ford Bronco Bronco Raptor hitch DIY install with pictures 2F29F66B-D3DE-48FE-B244-24BC7861AD24
Ford Bronco Bronco Raptor hitch DIY install with pictures E94DBBE1-182B-4F80-857E-007F7C7E8A9B
Ford Bronco Bronco Raptor hitch DIY install with pictures 597ABB25-D5FC-4976-829B-C67F173A92BF
Ford Bronco Bronco Raptor hitch DIY install with pictures FD7FB702-9350-496B-BB58-38B3B9C61BF2
Ford Bronco Bronco Raptor hitch DIY install with pictures C1A26AF7-D3C4-42C1-9BD9-CD8781B25C13
Ford Bronco Bronco Raptor hitch DIY install with pictures ED8A49CD-437B-4DB2-98A3-AE8C09CEEE2D
Ford Bronco Bronco Raptor hitch DIY install with pictures 74074495-775F-4486-9141-3BAE648EC186
Ford Bronco Bronco Raptor hitch DIY install with pictures CF67F41F-6526-4B72-96C2-E5FF25D7E183
da_jokker
Jeep Wrangler JKUR
Interesting. They made the flange bigger and thicker to spread out the pressure on the rear crossmember.
Personally I'm going to try to find some way to reinforce the hitch but I wasn't planning on replacing it unless it was with an aftermarket bumper or at least one that goes from frame rail to frame rail.
robepa
Paul
West Seattle, WA
www.instagram.com
2022 Bronco, 2006 Tacoma, 2020 4Runner
Awesome, this is what I am planning on doing with my Badlands. Do you have part numbers for the Raptor hitch and reinforcing parts?
Edit: Thanks to @flip Part number NB3Z-17D826-A
SurfsUp85
Joshua
Windsor, Ontario
youtube.com
2021 Bronco 4 door Outer Banks, Kia soul 4u
Score!!!
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
I have a dum question. Why are you using a Bronco Raptor hitch?
Rspayde
North Ga
2022 C/O Black Diamond
because more stronger uga uga boom boom. But on a real note there is paranoia with the stock hitch because a few idiots have damaged it.
flip
Phil
IN
www.ruxerparts.com
Fords
I have a dum question. Why ate you using a Bronco Raptor hitch?
A couple benefits of the raptor hitch is that it's built with a little heavier gauge steel than the OE version, has provisions if someone wanted to fab up the kicker bars (like Farmerjack) AND they have added a "tongue" below the 7/4 pin connector presumably to provide some protection when entering and leaving steep obstacles. Is it worth the price difference from the Ford accessory kit? That depends on what you're doing with your rig. You break the 7/4 pin connector off and that probably covered the difference between the two.
I put one on mine less the kickers.
Ford Bronco Bronco Raptor hitch DIY install with pictures raptor hitch 2
Jdyount
Jason
Kansas
2021 Badlands
The factory hitch is rated for the Bronco's tow rating. Let me repeat that: THE FACTORY HITCH IS RATED FOR THE BRONCO'S TOW RATING!
So the only reason to do this is if you plan on exceeding the Bronco's tow rating. Good luck if you get in an accident while doing so...
Edit: Ok, I read Flip's post, I do agree that the added protection for the connector is worth the upgrade. But still, don't be dumb and tow over the max, that still applies.
pwork
Patrick
Southern Illinois
GTI/Sportwagen/Frontier
Was wondering if this could be done, thanks for experimenting. The added strength of tying it to another cx member would be worth the piece of mind to me regardless of what one was towing.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Well that would make sense. I like it!
Rivers90
Ben
california
xterra mx5
Moving the muffler like you did also opens up the space for a hidden rear winch or some other behind the bumper mount item.
Free Pizza
Tommy
New jersey
Jeep cherokee
Many of us have wondered about this I'm sure. Thank you for posting it. Nice job.
MNBigfoot
MN
At what drop is that calculated? In Flip's photo that hitch has a drop of maybe 3 1/2"(?), if one uses that amount of drop, does max tow still apply?
