- Phil
- Jul 21, 2020
- 41
- 4,312
- 14,284
- IN
- Website
- www.ruxerparts.com
- Fords
- Badlands
The rubber around the right front wheel well was blown off because the push pins didn't hold. I assume this is due to the water pressure created either on initial entry or during the run through. Absolutely going to put a couple holes in the radiator support trim panel and some shielding under that hole so the water can drain off but not come up from the bottom. Also going to try and fill the gaps around the wheel wells and some sort of baffling that keeps a direct hit from the air inlet drain flapper. If the Raptor box was a direct fit I'd go with that because the filter is in the upper part of the box which means the actual air inlet tube are several inches higher than where it currently is.This is actually a very good point that I haven’t thought about. How susceptible are turbo engines to Hydrolocking? As you said in order to get into the cylinder it needs to get into the intake, through the turbo, through the intercooler and back up what is essentially a giant P-trap in order to make it into the cylinders.
Not that I want to find out And there’s probably some other issues but what’s the likelihood of actually Hydrolocking these? Also if you get water down to the inner cooler would the continuous hot air flow dry it out within a short drive?
@flip any thoughts having looked at this enough to plan your shielding.
Should not be this much crap in the box period. Subsequent pics show the evidence of up splash, not stuff coming down from the top. I may have hit the hole at speed but was well below fording limit. This was the first run, second outing with smaller mud hole wasn't as dramatic but still had stuff get in through the drain flapper.
One mod already, 4th pic down, I used some 3M rope caulk where the box and outlet meet because there was no obvious gasket. It was evident some water was pulled in at this junction probably because the air filter was partially plugged and vacuum levels higher. There's a small drain hole in the bottom of the box but didn't help much because I still had standing water in the socket where the bottom box half mounts to the body.
