There is nothing about this install that takes two hours. I mean, unless you make it into a drinking game.Is there another/new link for this video? I'm trying to prove to my dealer that his 2.0 hours to install is a joke.
Humm, had not thought about the back plate being wider, makes sense, thanks for the info.Having just installed it, I am going to say, nah... I don't think so. It's built to fit the back of the Bronco pretty exactly. So the panel that runs along the back of your seats is wider than the opening of the tailgate. And the panels that run back to the tailgate are too long to slide in through your side doors. But I'm open to being proven wrong. Video or it didn't happen.
B ack gate does not open if keyfob is not near itI'm always paranoid about locking a convertible and having someone cut the soft top. In the past I've left my jeep unlocked and locked valuables in the center console to avoid it, but if I did that in this case with a bronco they could open the back gate and gain access. I wish there was a way to lock the back gate separately to avoid this, but I suppose if it did get cut you could always claim it on insurance
I've got both this and the ez lift also, but cargo area was dealer installed and no rattle. At least not that catches my attention.Anyone run into a bit of a rattle with this? If so what was your solution?
I've got this and the IAG ez-lift system, but I installed at different times and didn't notice the rattle until after this was installed, so I think it's the raised lid cargo system.
I do want to modify mine though. Some sort of soft material topper for when things are strapped to it. May help as noise reduction too depending on material. Trying to figure out a way to make the top quick release also. And maybe mount compressor to the underside like TC Custom.Anyone run into a bit of a rattle with this? If so what was your solution?
i also have a light rattle now after install. Did you ever get a reply or figure out what is causing it?I've got both this and the ez lift also, but cargo area was dealer installed and no rattle. At least not that catches my attention.
Ok, feeling a bit stupid here….but I found the issue. The bolts that hold the top on weren’t tighten down all the way which gave the washers just enough space to rattle. Tightened those and issue solved.i also have a light rattle now after install. Did you ever get a reply or figure out what is causing it?
I have the Husky mat and it would not originally fit with the cargo enclosure, but I cut the mat down to size and it works just fine. I cut the passenger side edge and then had to widen the openings around the cargo tie downs to get it to lay down flat, but it looks fine and serves its purpose.Have any of y'all found floor mats that work with this enclosure?
