- Sep 25, 2020
- 16
- 3,147
- 8,197
- Western Maryland
- Sierra
- Base
Sounds kinky...If I activate Alexa, will I still be able to use Siri?
Posting this thread to be helpful for any warranty issues. I work at a ford dealer in north east Ohio, drive a bronco myself and have access to all TSB (technical service bulletins), Recalls, and portal messages. As well as the issues I see on the daily! feel free to conversate.
I chose Rokblokz and love them. All 4 were on in under 30 minutes after doing the prep/assembly. Their video is perfect for install. They block all of my gravel driveway that I take with me from hitting any paint and blend in so well, I forget they are there. https://rokblokz.com/products/ford-bronco-2021-mud-flaps. I'm not affiliated with them just love the product.The service tech made no mention of that being an issue. They are giving my return back in cash vs points, so whole new outlook if I choose to start over.
Here's mine...22 WildTrack, delivered last March. I've honked my horn twice, and I am NOT heavy-handed.Do you have a photo? Was a manufacturers defect?
I have this, too! Thanks for posting this. Usually happens when I am on a ferry (WA State).Any update on SSM 50951 2021-2022 Bronco - Equipped With Electronic Brake Booster (EBB) - Multiple Error Messages In The Instrument Panel Cluster (IPC) After Startup?
If I turn off the engine and sit without opening the door, I receive multiple failure messages when I restart the engine. The e-brake is also engaged even though I didn't set it. I'm hoping there's a software update for this issue. Thank you!
Sold. Simple enough I know I can do it, especially since I dont have to remove those pesky inner splash guard screws and not be in an awkward position trying to install them! Thanks for sharing. It was a blessing it didnt workout at the dealer yesterday and they could only refund points via cash.I chose Rokblokz and love them. All 4 were on in under 30 minutes after doing the prep/assembly. Their video is perfect for install. They block all of my gravel driveway that I take with me from hitting any paint and blend in so well, I forget they are there. https://rokblokz.com/products/ford-bronco-2021-mud-flaps. I'm not affiliated with them just love the product.
Looks like we should probably reserve one of the aux switches for a horn? I’ve always wanted one of those awesomely annoying hornsHere's mine...22 WildTrack, delivered last March. I've honked my horn twice, and I am NOT heavy-handed.
likely more of the same. I had to take mine back the next day after getting it. Ford under a lot pressure to pump these out cuz they know we wasn’t waiting another year, especially since the CyberTruck supposedly coming out this year and even Rivian is on the road. 500 mile range, 0-60 in 3secs, and and offroads too? Plus aint nobody driving gassers after 2035 if Greta gets her way.Just read 9 pages. Holy discouraging…my Bronco is inbound. How is all this shyte acceptable? So much random BS. Is this what is acceptable to all you normal Ford buyers? You guys like this vehicle that much to put up with up this stuff? What’s going to happen post-warranty? Not sure I can handle it, we’ll see. Wonder if MY23 is better or more of the same…
What size did you go with?I chose Rokblokz and love them. All 4 were on in under 30 minutes after doing the prep/assembly. Their video is perfect for install. They block all of my gravel driveway that I take with me from hitting any paint and blend in so well, I forget they are there. https://rokblokz.com/products/ford-bronco-2021-mud-flaps. I'm not affiliated with them just love the product.
I got the XL full set, I do have SAS package. They have this handy guide way at the bottom of the description page, I used it and they fit perfectly. https://rokblokz.com/blogs/news/what-size-mud-flaps-will-my-bronco-need.What size did you go with?
Yes. Manufacturers are consistently change blade materials to make better blades. Depending on what someone is using to clean their windshield, or their blades, they could be damaging the rubber enough to cause more resistance. Then, after an hour of using your wipers, the motor could become hot enough to trip this fail safe.Do you really believe that a wiper blade can become so sticky as to completely stop a wiper motor on a brand new vehicle. I’d have to believe that the blade would need to be tar to overheat a wiper motor….and on multiple broncos. Been driving 30 years, have never even heard of a wiper motor overheating because of “sticky” blades. And FYI, when wiper blades are old, they degrade and get brittle, not sticky.
