Disabling TPMS Sensors
ModifyMike
Ford F450
Has anyone figured out yet how to disable the factory TPMS sensors through Forscan? Adding aftermarket beadlock wheels which are not TPMS capable and wanting to have the light off on the dash.
ModifyMike
ModifyMike
Ford F450
I think TPMS is required by law, on vehicles this modern, in most states.
I could be mistaken.
Thatā€™s what I figured, was curious if someone had cracked the code to still disable it though. My 2017 F450 Platinum doesnā€™t have them so I would think it could be possible. Trying not the have that warning plus the check engine light.
Bob Blaylock
Bob
38Ā°29ā€² North 121Ā°26ā€² West
2016 Dodge Dart
I'm guessing that any modification that lets you not have the TPMS light on, when there are not TPMS sensors in your tires verifying that the pressure in them is adequate, would be illegal.
Now, if I were determined to defeat a TPMS, my approach might be a bit more brute force. Obtain or construct some small, pressurizable container, mount the TPMS sensors in it, and pump it up to the necessary pressure to satisfy them.
I wonder if it's possible to obtain or create fake TPMS sensors, that put out a signal indicating good tire pressure, without actually sensing the pressure. Similar in concept to ā€œMIL Eliminatorsā€, but to fake good tire pressure readings rather than to fake good catalytic converter readings.
ModifyMike
ModifyMike
Ford F450
Iā€™ve actually already thought about what you are proposing, small pvc pipe with a cap on each end ant a tire valve drilled in. Pressurize to the desired pressure and perfection! Iā€™ve done a little bit of reading online with other ford vehicles and it seems there is already fixes but nothing that has been confirmed on a bronco. I know Iā€™m not the only person who is going to run race wheels on a bronco so fixes will come in due time.
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'75 Intl D150/'22 Badlands
Theoretically could be done in Forscan, but not sure how far people have gotten decoding things.
ModifyMike
ModifyMike
Ford F450
Thatā€™s what Iā€™m thinking, was hoping not to be the Guinea pigšŸ˜‚
ModifyMike
ModifyMike
Ford F450
Worst case, put a small piece of this over the warning light:
Ford Bronco Disabling TPMS Sensors 1635898928755
Sadly would be a big piece, because on these it throws a check engine light šŸ˜‚
chtucker
Kirkland, WA
FJ Cruiser
I am having my beadlock wheels have double valve stems, TPMS valve stem on the inside and monster valve on the outside. The warning light would set off my OCD. I can handle to light on the trail, just not a daily basis. Also figure it might be an early
warning to an issue with the beadlock.
i am having Trail Ready make my wheels
AtomJester
Adam
Benton Harbor, MI
1988 Ford Bronco ii
Someone posted about changing the wheel size in forscan earlier today, with a video. The video also included how to change your tire pressure threshold for triggering a notice/warning. I assume you would be able to change it down to whatever PSI you plan on running. Idk where the thread is, try the dreaded search function.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
like reverse cameras, manufacrturers have to include the system but you arenā€™t going to get arrested for not using the system or disabling it altogether.
ShroederK
James
Jeep Wrangler
This is actually interesting to me. All itā€™s doing is sending a wireless signal to the computer which probably isnā€™t encrypted. If thatā€™s the case, you should be able to capture the data and replay it. I have the equipment to analyze what is being sent. Iā€™m going to have to nerd out on it this weekend. Just for the challenge.
Charky
Duane
Little Rock
A7
Well, that sucks. You'd think a check engine light would come on for only engine specific issues, but not these days. Hopefully a programming work-around will be created in the near future.
ModifyMike
ModifyMike
Ford F450
These Methods are single valve stem but the problem is the mount itself in inset to the whee so it could potentially work with a spacer.
Ford Bronco Disabling TPMS Sensors 664C5C51-C772-49A2-9858-A516E5997AE4
