- Bryan
- Jul 25, 2020
- 44
- 724
- 873
- Charlotte, NC
- 1981 CJ5, 2015 BMW M4, 2019 Jeep G.C. Trailhawk
- Badlands
- #121
Ok, I will get back tomorrow to look at what other fuses I am using. But just so you know, I have a Oracle kit as well and it has a memory save function to make different colors, lighting patterns, etc. I originally had it hooked up to a fuse that is only on when engine on and it would always lose my saved presets requiring me to painfully reprogram it. (has no battery backup). I then moved it to a fuse that is switched on all the time to avoid that. This works as long as you can manually switch it on and off between the module and the light sources themselves. Just a thought. You may have a different system as they make a ton of them. Below is the DIY post I made about that setup:Still unresolved. Would like for it to be on so long as the engine is on. Already cut the ac adapter off so I’m dedicated to hardwiring it at this point.
https://www.bronco6g.com/forum/thre...console-for-led-lights-and-power-steps.36706/
Update, I just reread the above to remind myself how I wired it. I am actually using the same fuse locations for my lighting kit as I am for my dashcam (#35 and #29). As long as the rated power (amps) do not exceed the rated fuse, you can split a wire off of those same locations and do the same. Let me know if you have other questions.
