I did the UCA’s. I swapped the springs in front to the 550lb springs and got 3” in the front so decided to add them.anyone do UCA's or feel like they should have
I did not do the track bar bracket right away, but added it later. Alignment was acceptable, and street ride was ok, till I hit really large bumps at higher speeds, then I could feel that little bit of rear shuffle. It was driveable, but the track bar bracket made it perfect. I also added rear spacers to even out the lift, so mine really does need the track bar lift bracket now. Most heavier 4drs probably don't need itFor those that did springs-only upgrade to squatch bilsteins:
Did you also do track bar bracket or is fresh alignment sufficient?
Do your Icon UCAs make noise when moving over bumps? Mine does make a noise even though they are well lubricated.I did the UCA’s. I swapped the springs in front to the 550lb springs and got 3” in the front so decided to add them.
No problems with the UCA’s making any noise on mine.Do your Icon UCAs make noise when moving over bumps? Mine does make a noise even though they are well lubricated.
The instructions say to cut down the bump stops. I didnt and i dont think anyone else on here did either but that may improve your issue
I did trim the bump stops when I installed them. Maybe I should trim some more off. I’m gonna give it a little before I mess with it.
Are you also experiencing the top out issue? Based on mine I would assume it would be pretty bad without the bump stops trimmed.
I did trim them during install.
Do you have an extra weight upfront, like a winch or something?
This is incorrect.I don’t think trimming the bump stop would matter if the shock is topping out. Messing with any bump stop would only effect it on the compression not the extension. Don’t quote me im not a shock guy but I think they want you to trim the bump stop so the spring will be fully compressed when it touches it. If it doesn’t it’s going to put more strain on the bump stop it self and not take some of that load off in the spring.
Sorry if this is a stupid question but this is my first time attempting anything like this.
Do I need any special tools to swap to the 550 lb springs? I haven’t installed this lift yet so the coilovers will be fresh out the box
I mean both the shocks and the coils will be brand new and not installed on my bronco. Would I still need a compressor to do that?Assuming you mean "coils" will be fresh out the box. I swapped springs in this past weekend so it's fresh in my mind.
I have replaced springs about 5 times in different cars but this was my first offroad vehicle. the rears went smoothly and quick. the fronts were much tougher. the fronts are stiffer and need more compression. I was using a cheap loaner compressor from an auto parts store and ended up having to rent a 2nd compressor set to get it done. the 1st compressor would not grab enough coils.
If i need to do it again i will take the coilovers to a shop to have them swapped. It's a 20 minute swap with the right tools and much safer.
Ok thanks for the info. Was the loaner set you used the one that goes on the outside of the spring?you would. you have to compress the installed spring to get the strut top off. then uncompress it. then compress the new spring to install on the strut and get the strut top back on. then uncompress and install the coilover on the rig.
A bit of advice. If you aren’t mechanically inclined or have never/don’t know how to compress a spring, you really should let a shop do it. Those spring compressors that you rent can be extremely dangerous if you don’t know what you’re doing. Especially on such a heavy rated spring. I’m all for installing your own mods, but this one might be best left for the shop. They don’t call them widowmakers for nothingOk thanks for the info. Was the loaner set you used the one that goes on the outside of the spring?
Just installed the Eibach 2.0. Now I have to decide 35's or 37's???
