- Apr 30, 2021
- 39
- 1,405
- 2,821
- Portland, Oregon
- 19' Jeep Grand Cherokee High Altitude
- Badlands
I got my 2023 bronco and decided to go a completely diff route. I was going to do eibach coilovers until I heard they used the same soft springs. Went fabtech dirtlogic and couldn’t be happier. I’m about 220lbs and when I sit on the back of the tailgate it barely lowers the bronco. Zero body roll and the on road comfort is incredible. Quite a bit more expensive thoughAfter looking into this for a few days, I'd say don't hold your breath on Eibach coming out with a stiffer spring rate for the OEM coil overs. Just not a market for it, and would cause more confusion/problems with their customers.
My suggestion is to upgrade to the offered springs and make up the rest of the desired ride height with spacers, either under the bottom mounting bolts, top of the tower, or perch spacers. If you want more than 1" over factory height or more suspension travel then go with a fully adjustable aftermarket coil over solution.
